How to wire OTRATTW backlit switches - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to wire OTRATTW backlit switches
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRIGID LED Light Blowout Sale - All Sizes, All Series, all Stainless Steel Door Hinge Pins
Unread 09-08-2014, 02:57 PM   #1
Madden_07
Hey all,
I recently got a set of switches from OTRATTW and they're fantastic, I was just wondering what wire I need to tap into to have them illuminate when I turn my headlights on. I'd rather not just start cutting wires unknowingly so I figured I'd ask you guys for some help
"Roads? Where we're going we don't need roads!"
-Dr. Emmett Brown
Madden_07 is offline   Reply With Quote
Unread 09-08-2014, 03:05 PM   #2
2jhanna
Since you have an auto tranny, isn't there a small bulb underneath the Gear indicator by the shift lever. One side of the bulb should be ground, the other side should be controlled by the headlights.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Unread 09-08-2014, 05:24 PM   #3
_KONG_
There is a wire behind the dash that says "illumination". I used it for my trans temp gauge so it turns on and dims with the dash lights
_KONG_ is offline   Reply With Quote
Unread 09-08-2014, 07:11 PM   #4
Madden_07
Any idea what color the wire would be?
-Dr. Emmett Brown
Unread 09-08-2014, 07:36 PM   #5
_KONG_
Unread 09-08-2014, 07:38 PM   #6
Madden_07
Awesome, thanks!
-Dr. Emmett Brown
Unread 09-08-2014, 07:49 PM   #7
dillonjm
30mm @ 70/sec
dillonjm's Avatar
Don't just blindly trust colors. Get out a multimeter or at least a test light and check for voltage only when lights are on.
That'll keep you from splicing into the wrong one and making a mess of your harness.
03 Rubi on 35's (Weekend Toy)
11 Ram 2500 - 6.7 Cummins (DD/Tow Rig)
05 Liberty Limited (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is online now   Reply With Quote
