How to wire LED turn signals/Running lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to wire LED turn signals/Running lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winch sale-- Best deal you will find. and FREE SHIPPIFree Air Compressor with Purchase of ARB air locker
Unread 08-05-2011, 05:14 PM   #1
JASON_77
want to wire my turn signals and running lights together. can some one post up a diagram and or whatever parts are needed? thanks
~Jason~
1998 TJ 4.0L,2.5 Skyjacker,1.25 JKS, MML,Flat belly,35-12.50-17 Mud Grapplers,17x9 Classic Locks,HP30/8.8 4.56
2000 WJ 4.7, 6.5" LA, 33's, 4.56's
JASON_77 is offline   Reply With Quote
Unread 08-05-2011, 05:50 PM   #2
freeskier93
"Generation Dead"
freeskier93's Avatar
Uhh, can't be done. For starters they are two different intensities and turn signal wire is shared with the brake light wire.... what are you trying to accomplish?
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
Air Force ROTC Det 105
freeskier93 is offline   Reply With Quote
Unread 08-06-2011, 11:36 AM   #3
JASON_77
Wanting to accomplish one light, two functions.
~Jason~
Unread 08-06-2011, 11:55 AM   #4
Whobeme
Do you mean something like this for LEDs?
Whobeme is offline   Reply With Quote
Unread 08-07-2011, 07:03 PM   #5
JASON_77
yes, that is what i am after. just have to get the diodes/resisters
~Jason~
Unread 08-07-2011, 07:11 PM   #6
AirborneCav
Senior Airborne Scout
AirborneCav's Avatar
Any idea of what size diodes and resisters to get?
SILVER JEEP MEMBER #15
When its time to clean up... http://www.detailedimage.com
AirborneCav is offline   Reply With Quote
Unread 08-07-2011, 07:27 PM   #7
JASON_77
Tried a search the other day on this subject, did not see
this.
http://www.jeepforum.com/forum/f9/le...ation-1081228/
~Jason~
Unread 08-07-2011, 07:32 PM   #8
inglisleslie
look in the thread 2 to 3 wire LED...
I had so much trouble with it and i have to pass inspection next week i just kept my 3 wire blinkers taped up in the engine bay for now...I did the resistor diode modification...only problem is that i could only get the blinker to work with the headlights off...Once i turned on the headlights all the blinkers didnt work and switched over to putting out the 50% running light power...grrrrr
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline   Reply With Quote
Unread 08-07-2011, 07:32 PM   #9
inglisleslie
you will soon learn all about the floating ground
/l ,[ ______],
()_) ()_)--O-)_)
Unread 08-08-2011, 10:40 AM   #10
silverjeep
It can be done. You need some stuff from Radio Shack. Check out my build thread.
Disclaimer: I haven't gotten to the rear brake light yet.
CHECK OUT MY LJ BUILD THREAD
silverjeep is offline   Reply With Quote
