Quantcast How To Use Rubicon Lockers Sperately and in Hi Range??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How To Use Rubicon Lockers Sperately and in Hi Range???
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 12-28-2009, 12:45 AM   #1
1badxj
I will soon be the proud new owner of a 2006 Rubicon LJ!!! I have searched and can't seem to find how it is you go about bypassing the stupid factory safety lockouts on the lockers, and wiring in a 2nd switch to operate them individually from each other.
New Toy: 2005 Rubihara #111 of 1000
Wife's: 2005 Liberty CRD
2.5"lift, Rock Lizard rock rails, Front True Trac, Rear Powertrax N0-Slip locker, & 31" Duratracs on 15x7 rock crawler rims
Tow Rig: 2003 Silver Reg. Cab Dodge 2500 2wd
5.9 Cummins (lots of mods) dyno proven 550+rwhp
1badxj is offline   Reply With Quote
Old 12-28-2009, 01:48 AM   #2
SnowYJ
Pavement Pounder
SnowYJ's Avatar
i second this question!
Account kindly upgraded out of pure kindness! JeepForum is like a second family.
Originally Posted by Slickbr View Post
Rules for the JEEP:
1. Yes, the suspension is same design as a covered wagon, & so is the soft top; it worked for the Cowboys & settlers.
SnowYJ is offline   Reply With Quote
Old 12-28-2009, 02:32 AM   #3
Sccafire
KMG 365
Search is your friend. Took all of about 10 seconds to find.
http://www.jeepforum.com/forum/f9/rubicon-locker-modification-503524/#post4629460
Scott
"life is good at 2 MPH"
Sccafire is offline   Reply With Quote
Old 12-28-2009, 07:38 AM   #4
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Avatar
there is a technical write up on this.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Old 12-28-2009, 09:01 AM   #5
andito77
Go to:
Rubi Locker Switch Bypass - 1
Please donate money (every little bit helps) to help keep the website going, as that website has helped countless Jeepers to do mods to their Heeps.
*note* I've never met Stu, and have nothing to do with his website, besides using it to do a few modifications.
andito77 is offline   Reply With Quote
Glock Forum
