How to unstick torx bolts on half doors - JeepForum.com
post #1 of 13 Old 07-13-2010, 08:21 AM Thread Starter
Nasty73 Z-28
Hi, I just bought some new to me have 1/2 doors for my LJ. The Passenger side fits fine... the drivers side you have to lift up on for the latch to catch. I did a search and learned the hinge is adjustable. The problem is I cant get the Torx screws to budge...Any advice?
2006 Rubicon Unlimited
O.M.E , JKS, Currie, 33's
ARB Stubby, Warn M8000
Nasty73 Z-28 is offline
post #2 of 13 Old 07-13-2010, 08:36 AM
-dirt-
I was too scared to try to loosen the torx bolts when I needed to adjust some full doors. I heard horror stories of the torx head stripping out, taking the paint with it, and then the paint under/around the hinge not matching once I adjusted it.
So, I ended up "tweaking" the door pins. You can put the nuts back on and then lift the door from the latch. (A body shop has a tool for this. Looks similar to a hi-lift.) Took about a minute. Essentially it just bent the pins enough to get the striker and latch to match up.
EDIT: But I have read where several people have been able to adjust their hinges with success.
-dirt- is offline
post #3 of 13 Old 07-13-2010, 02:22 PM
roadbosstx
I have to adjust my strikers whne changing from 1/2 doors to full doors. I mark the striker pin location on the body for each set of doors, to take the guess work out each time.
roadbosstx is offline
post #4 of 13 Old 07-13-2010, 02:37 PM
JFjeld
I bought new hinges for my half doors a few years ago and had a problem with the Torx stripping. I ended up drilling the screws off and it was a real pain.
01 TJ,HPD30/D44,OX,4.88,35s,1"BL,1"MML, 4.5" lift,OBA,Novak Shifter,Teraflex ESS SYE, UCF tummy tuck
JFjeld is offline
post #5 of 13 Old 07-13-2010, 02:48 PM
only in a jeep cj
I rarely strip a torx bolt due to using heat. Even on painted surfaces, if you use few seconds of heat on and off several times and slowly heat the bolt to under the point of messing the paint up, 9 out of 10 times, it will soften the factory thread locker used on all the body torx bolts and it will easily come out. I have the best luck with the yellow MAP gas.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #6 of 13 Old 07-13-2010, 03:05 PM
MTpockets
MTpockets's Avatar
put some heat on them. but not so much to burn your paint, if you care.
1997 TJ 5.5" long arm kit, 35x12.50 bfg m/t's, d44 front/rear 4.88 gears with arb lockers
ALWAYS ACCEPTING DONATIONS!!!
MTpockets is offline
post #7 of 13 Old 07-13-2010, 03:13 PM
NCUNLIMITED
Not to hijack your thread still on the same lines....How do you adjust the hinges once you get the torx bolts out??
NCUNLIMITED is offline
post #8 of 13 Old 07-13-2010, 05:03 PM
only in a jeep cj
I just picked up a TJ, but I believe the adjustment is the same as the many CJs and YJs Ive worked on. The upper WS hinge is fixed while the door hinges are on floating nut plates. With the striker out of the way, have all the door bolts just loose enough so as the hinges can moves side to side and up and down. The trick is to first match the lower and side door lines to the tub lines so the gap is the same all around. Don't worry about the WS frame or top right now. Next tighten up the lower tub hinge, but bring it up a tad to preload it so it shares the weight with the upper hinge. Next, adjust the striker pin (U shape latch part on tub). The spreader bar has an adjustment bolt that will allow the rake of the WS to move a bid to get an even gap along the WS frame and door. Then the top is last and should line up to the door and tub holes. It might take a few times, but thats how I adjust them and it works out good.
Ed
1975 CJ-6 1983 CJ-8
post #9 of 13 Old 07-13-2010, 06:37 PM
glockster
I don't even bother with the door gaps.
I did however remove the weatherstripping from around the door the first time I mounted up my half doors. I did not want to touch the striker because my full doors worked flawlessly. With the weatherstripping removed, I just adjusted the upper and lower hinges until the half doors latched easily. Then I reinstalled the weatherstripping which made the doors difficult to close and latch but I knew the doors were adjusted properly. Once the new weatherstripping got smashed and formed to the door jams they now work pretty damn good.........but still not as good as the full doors.
Marco
glockster is offline
post #10 of 13 Old 07-13-2010, 08:22 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Impact driver and some heat if needed... an air impact gun works wonders as well.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #11 of 13 Old 07-13-2010, 08:28 PM
durango-bob
2006 WK
I have had very good luck using a hand impact tool from Sears. It's the one that you put in the proper bit, hold it on the bolt and whack it with a hammer. I have never had one strip and there is no risk of burning the paint.
durango-bob is offline
post #12 of 13 Old 07-14-2010, 02:03 AM Thread Starter
Nasty73 Z-28
Well... I managed to get 5 out of the 6 removed. The last one is pretty well stripped. Any suggestions. BTW, a friend told me to put the torx bit into the screw and give them a couple of solid whacks. Seem to work..Thanks
post #13 of 13 Old 07-14-2010, 04:01 AM
Fropleyqk
Fropleyqk's Avatar
This is what I use. Works like a charm.
edit: here ya go:
http://www.sears.com/shc/s/p_10153_1...5&blockType=G5
Fropleyqk is offline
tj , wrangler , half door , torx , stuck , adjustment , hinge
half door rubber seal issues (2nd sent of half doors) sail78385 TJ Wrangler Technical Forum 0 06-19-2010 01:59 PM
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
2006 half doors vs, 2007-09 half doors crashtom Wrangler General Discussion 1 06-11-2009 02:12 PM
TJ Soft half windows on YJ half steel doors? DavesMatthew YJ Wrangler Technical Forum 5 04-17-2004 11:25 PM
