How tough is your jeep? - JeepForum.com
post #1 of 6 Old 05-07-2001, 01:11 AM Thread Starter
Draven
I have a 97 green tj. mostly stock with 30" tire's and canyon wheels. I've had it for over a month. i've put some scratches on it already. anyway, i was wanting to know how hard can i drive the thing. I mean down some old gravel trails and stuff. would you drive jeep so hard to bottom out the springs?
Also i know no one who has a four wheel drive. the first week i had the think i buried the thing not knowing how to drive. or could it be the tires? I've the goodyear wrangler tires on. i went wheeling today in some sand+mud. sorry to say that i chickened out in going where i wanted. don't get me wrong, just did not want to get stuck all alone with no one else for a pull. I did go half way but the tires were full of mud and not cleaning themselfs.
Draven is offline
post #2 of 6 Old 05-07-2001, 10:56 AM
Real-LD
When you say hard do you mean fast? I think it's more a control issue. Drive within your abilities. You don't want to constantly bottom out, unless you don't mind ******* out tons of money to replace all that is envolved in driving likes that. What I'm saying is this kinda of driving put sume serious wear and tear on any machine.
Sometimes the mud just gets to deep and getting stuck is unavoidable. What kind of Goodyears you got. Tires could be a part of it. But If it gets way deep ain't no tire going to get you out unless you got them axle roll tires that just came out. J/K
Yeah getting stuck all by your lonsome sucks, but hey getting out is a great feeling.
Rock out with your crack out and call me monkey boy.
Peace
Lar-re D.
97 Tj not so stock but not so modified.
Real-LD is offline
post #3 of 6 Old 05-07-2001, 01:49 PM
JEEP_TJ_FREAK
Those stock tires have gotta go. I as you can see I'm from Tulsa as well, and I've got some used wheels, tires, experience and trails I can show you just keep posting.
p.s. where were you to get stuck, the river? don't do it man. I've seen many a truck washed away by the core of engineers.
I UNDERSTAND
4 Banger TJ on 36"s
2000 WJ Limited 4.7 Q-drive for daily use, bone stock.
JEEP_TJ_FREAK is offline
post #4 of 6 Old 09-19-2004, 05:31 AM
rockon1202
rockon1202's Avatar
Unless they're mud tires, you know you'll get stuck right off. But, if you were going out in mud/sand, you want to make sure you deflate the tires a bit. That extra surface area contacting the ground will make a huge difference in how easily you get stuck. Anywho, a winch will solve your getting stuck problem, unless you wheel with a buddy, and then all you'll need is some tow straps.
rockon1202 is offline
post #5 of 6 Old 09-19-2004, 07:53 AM
htownjeep
What's that noise?
htownjeep's Avatar
I know you said you don't know anyone that has a 4wd vehicle, but that is one of the first rules of offroading...don't go wheeling by yourself! Especially when you are so new to it. Have you looked into clubs in your area? You can really learn a ton just by being around people who have done it before and see it in real life instead of having it described to you by all of us!
I'm sure you'll get tons of great advice from all of us here, I have already seen some. But it pales in comparison to actual hands on advice/instruction.
ps-not going in when you didn't know what to do isn't chickening out, sounds like you probably saved yourself some time and money!
Drink upstream from the herd.
htownjeep is offline
post #6 of 6 Old 09-19-2004, 02:53 PM
Dragonmaster
Dragonmaster's Avatar
IMO the only good goodyear tires are the MTR, that's why so many vehicel manufacturers have the goodyears as standard tires, because they are cheap. Get yourself some good a/t's or some mud tires and definitely join a club or find some people who wheel and don;t go alone.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
Tough one... kenski83 TJ Wrangler Technical Forum 37 06-28-2006 05:17 AM
Here's a tough one tzuccarell TJ Wrangler Technical Forum 4 10-05-2005 10:33 AM
One Tough Jeep rattletrap TJ Wrangler Technical Forum 11 05-23-2005 10:36 PM
Help with Tough Look!!! jeepster38 TJ Wrangler Technical Forum 2 01-31-2004 05:21 AM
