How to tell which transmission you have. - JeepForum.com
post #1 of 2 Old 06-19-2007, 10:32 PM Thread Starter
GilpinTJ
GilpinTJ's Avatar
I go to Stu's web site to see what quantity of fluid I need for a 5 speed manual transmission fluid change and there are 4 different transmissions listed for TJs. How do you tell which one you (I) have? I'm sure it's a simple answer, but I "searched" a bunch of times with no results.
My Owners Manual says fill until the fluid is pouring out of the hole, but I still want to know what I have.
Thanks!
John P.
Colorado Jeep Club Member #494
GilpinTJ is offline
post #2 of 2 Old 06-19-2007, 10:41 PM
2003Rubi
2003Rubi's Avatar
Assuming you have a 4.0 (they are standard in a Sport right?) you should have an AX 15.
http://www.novak-adapt.com/knowledge/ax15.htm
2003Rubi is offline
Installing transmission: to install transmission and t-case as a unit or separately? Arron TJ Wrangler Technical Forum 8 10-03-2009 04:10 PM
what to do with my AX-5 transmission ?? vans9140 Wrangler General Discussion 0 03-15-2009 01:56 PM
new transmission going in... advice for transmission n00b? VABYJ YJ Wrangler Technical Forum 5 07-10-2007 07:43 PM
bad transmission? OutDoorDawg TJ Wrangler Technical Forum 12 07-08-2007 04:34 PM
transmission CRAZYJ1988 YJ Wrangler Technical Forum 12 01-31-2006 01:36 PM
