How to tell which fuel injector is bad? - JeepForum.com
post #1 of 12 Old 07-22-2011, 02:42 PM Thread Starter
mccraneyj
Hey guys got another one for ya! My 02 six cyl wrangler is running very rich got my cat changed and muffler they are filled with soot. I got all the signs of a bad fuel injector my question is how do you know which one is bad
J-BEAR
mccraneyj is offline
post #2 of 12 Old 07-22-2011, 02:57 PM
herbiehind
any codes? you'd have misfire codes . also what's your current mileage ? how are your plugs? unplug each injector one at a time and see if it changes . bet it will . many things can cause rich , like 02 sensors . how many miles ?
herbiehind is offline
post #3 of 12 Old 07-22-2011, 03:09 PM
Varnish
Varnish's Avatar
I was just troubleshooting some injectors last night and what I did was buy a cheapo 6 pack of those little clear plastic water bottles. I emptied em, pulled the fuel rail, surrounded each injector with a bottle. I had to twist some of the injectors to get the plugs to reach the harness with the rail pulled out. I unplugged the coil pack and then had somebody turn the engine over and watched for the pattern. Worked great. You could tell both from seeing the spray and also from the quantity of fuel in each bottle. Wear safety glasses, no spark/fire nearby, and keep an extinguisher handy. If you have a leaky injector you may not even need to turn over the motor, just pressurize the rail by putting the key in the run position a few times and see if any are dripping.
'06 LJ, '88 YJ
Varnish is offline
post #4 of 12 Old 07-22-2011, 03:11 PM
Varnish
Varnish's Avatar
Even easier actually is you could pull the plugs and look for a black one.
'06 LJ, '88 YJ
Varnish is offline
post #5 of 12 Old 07-22-2011, 06:08 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I use a $5 mechanic's stethoscope to listen to each injector. A bad injector will often sound different from the others.
Jerry Bransford is online now
post #6 of 12 Old 07-22-2011, 06:20 PM
kloppk
X2
I just use a large screwdriver as a stethoscope. Just put the handle against your ear and then touch the blade of the screwdriver on each injector. You'll hear the injectors clicking. Just listen to each one at a time. A bad one will sound different from the rest.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 12 Old 07-22-2011, 06:42 PM
gmiller0737
If it's running rich there could be a injector leaking fuel,Test by pulling the fuel rail with injectors attached turn key on with engine off & look at each injector to see if 1 is dripping fuel.
gmiller0737 is offline
post #8 of 12 Old 07-29-2011, 08:26 PM Thread Starter
mccraneyj
Hey guys thanks for all the replys my jeep has just hit 100k but it has been doing this for the past 20k or so. Hopefully some time this weekend im gonna try all of your suggestions and see what i come up with. Oh and also I do have a cel light on its the large leak detection code but i have changed all the vac lines and solenoids but light still comes on but i heard this wouldnt cause my jeep to run rich? My jeep also has very poor acceleration.
J-BEAR
post #9 of 12 Old 11-18-2011, 08:30 AM Thread Starter
mccraneyj
Checked all injecters they all seem fine i pulled them all out and turned the motor over and none are leaking so i put them back in and bought mechanic's stethoscope that the Man Jerry suggested it wouldnt hurt to have one anyway. All the injectors sounded fine so now im gonna look into the o2 sensors.
J-BEAR
post #10 of 12 Old 11-18-2011, 08:47 AM
chris142
A bad MAP sensor can make it run rich too.
chris142 is offline
post #11 of 12 Old 11-12-2012, 02:12 PM
delgajac000
I am not sure if this was posted already but to test a fuel injector take a ohm meter and put one lead on one of the leads in the inside but close to one side. then put the other lead on the other prong on the opposite side. check link for a you tube video on how to tell.
make sure you DO NOT put the meter to volts or anything else!!!
delgajac000 is offline
post #12 of 12 Old 11-13-2012, 05:02 PM
chevy2169
Originally Posted by kloppk View Post
X2
This and this x3.
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
Fuel Injector Problems ColoradoCole TJ Wrangler Technical Forum 17 06-07-2011 02:58 AM
fuel injector/fuel rail removal HELP Gatornation TJ Wrangler Technical Forum 4 05-18-2011 11:29 AM
Fuel Injector Issue s93jeep YJ Wrangler Technical Forum 2 03-09-2010 07:22 PM
Help Fuel Injector Problem simpsonsdotcom TJ Wrangler Technical Forum 4 05-01-2009 06:56 AM
fuel injector ZachAttack923 TJ Wrangler Technical Forum 1 04-27-2009 12:27 PM
