How strong is the Ford 8.8 axle? - JeepForum.com
post #1 of 9 Old 04-03-2004, 08:55 AM Thread Starter
jeepman14wheel
jeepman14wheel's Avatar
Just wondering how strong is the Ford 8.8 axle. Is it worth the swap or not? Yesterday I had to complete a 5 hours axle repair on the trail when my friend broke his pinion gear in half on his Dana 35 rear axle. He had to drive home in front wheel drive with the pinion removed from the rear axle. That as a b*#$@ of a repair job on the trail. I think that 35" tires and a Dana 35 are no match on solid granite!! I will post pics when I get them of th is trail repair!!!
jeepman14wheel is offline
post #2 of 9 Old 04-03-2004, 09:08 AM
igofshn
Locked @ both ends
igofshn's Avatar
It doesn't take a rocket scientist to figure that one out.
8.8 is a very good axle and you probably wouldn't break it, but it is a c clip. For the amount of work it would be, you could go with a 9" and not worry about c clips.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 9 Old 04-03-2004, 09:29 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I wouldn't worry about the 8.8's c-clips, they're not usually the part that breaks anyway. An 8.8 is definitely way stronger than a D35c, but I'd just find a used Dana 44 out of a TJ since it's a much simpler bolt-up installation.
Jerry Bransford is online now
post #4 of 9 Old 04-03-2004, 10:25 AM
MasterCujo
MasterCujo's Avatar
I have one on my TJ, just installed days ago. Very strong axle, comparable to the Nine inch in most cases. The down side-if you want to call it that-is it is a C-clip. I however don't see anything wrong with it, and the difference between the 35 and 8.8 is night and day.
'98 BOR HEMI in OD green paint
MasterCujo is offline
post #5 of 9 Old 04-03-2004, 10:50 AM
JeepCrawler_98
JeepCrawler_98's Avatar
Its carnage stories like that and my own personal experiences that make me glad I got a free Chrysler 9.25" in works in the garage
To answer your question - the 8.8" is plenty strong. about the strength of a 9 inch, but at normal TJ width. I've wheeled with several people running 35s on em with ARBs and they hardly, if ever, break (granted theyre responsible on the gas and not a hammerhead driver) - and down here in rocky AZ, if theres a weak spot in your drivetrain; you'll find it REAL fast.
New kid on the block!:
JeepCrawler_98 is offline
post #6 of 9 Old 04-03-2004, 11:39 AM Thread Starter
jeepman14wheel
The gas was a factor in the break and he was running 35 + stock gearing! Not a good choice, we was having a hard time maiking obstacles with that high of gearing. I am just wondering what to do now, I think I am gong to go for the 8.8 or 9 inch. I like the thought of the 8.8 having disk brakes and same lug pattern.
post #7 of 9 Old 04-03-2004, 12:03 PM
runmanpkll
i recently watched an 8.8 being installed into a TJ. a couple things that i didnt like were, the pumpkin is off set to the right so the driveshaft isnt a straight shot from the pinion to the transfercase output shaft. the jeep had a 4" short arm lift without an adjustable rear track bar so when the rear axle assembly dropped it cocked at an angle where the right rear tire was almost rubbing the front of the fender flare & the left rear tire was almost rubbing the rear of the fender flare. (rear steer angle). the pinion is really long making for a really short drivesahft, and it seemed to have a rather large pumpkin which would want to get hung up alot. just a few observations, take then for what theyre worth.
runmanpkll is offline
post #8 of 9 Old 04-03-2004, 12:16 PM
JeepCrawler_98
I would think low gearing would make for a more vulnerable axle since it transfers more torque to the ring gear, carrier/locker, and axle shafts. Unless of course the gearing is so high that you're jagged at -=-=-=-=-=-=-=-= on the throttle - then you need driving lessons.
post #9 of 9 Old 04-03-2004, 01:39 PM Thread Starter
jeepman14wheel
The gearing was 3.07 in the rear, way to high for 35 and yes the throttle was applied a lot to get over the granite slab. I do agree, the driver needs some lesson/experience in that department.
How Strong is a Super 35 Rear axle 04Xman TJ Wrangler Technical Forum 6 11-27-2009 08:35 PM
ford axle csae-otj YJ Wrangler Technical Forum 1 10-01-2009 01:16 PM
Looking into Ford 8.8 Axle SoCal4x TJ Wrangler Technical Forum 10 08-10-2009 12:16 PM
Dana 30, ford 8.8 : strong enough for 38's? Andy4802 TJ Wrangler Technical Forum 27 11-04-2008 06:56 AM
Need a 44 axle or ford 8.8 zuck2001 YJ Wrangler Technical Forum 1 08-09-2001 03:39 PM
