how to straighten steering wheel? - JeepForum.com
post #1 of 51 Old 01-05-2008, 12:08 PM Thread Starter
losfreddy
i just put in a replacment tie rod and the alignment is mostly straight.. But now the steering wheel is to the side. How to straighten it out? pull the pitman arm, striaghten wheen and re attactch? Will the shop be able to do it if i brought it in for an alignment?
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks.
losfreddy is offline
post #2 of 51 Old 01-05-2008, 12:17 PM
djt283
djt283's Avatar
It's really easy...takes 5 minutes. It's the second half of this write-up, after the alignment instructions:
http://www.4x4xplor.com/alignment.html
djt283 is offline
post #3 of 51 Old 01-05-2008, 12:37 PM
MtnHighTJ
MtnHighTJ's Avatar
I have tried this and I am maxed out/in. Can't get any more adjustment out of drag link to completely straighten steering wheel
5spd Banks Monster exhaust
Dana30 ARB Locker Dana 44 LSD 4.88's
4" Explorer Pro Comp lift
1 1/4 JKS BL Brown Dog 1" MML
RE monos Nasty's Disco's
15"x 8" soft 8's w/ 35"x12.5'' MT Baja MTZ
A to Z sliders. Nth degree oil pan skid
Rokmen gas skid steering skid Warn dif plate
Superwinch EPi 9000
Currie HD Tie rod
BESRK rear bumper w/swing out
Colorado Jeep Club Member #85
MtnHighTJ is offline
post #4 of 51 Old 01-05-2008, 12:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Then you're doing something wrong. Is the steering wheel unlocked so it can turn?
Gone on vacation until August 25.
Jerry Bransford is offline
post #5 of 51 Old 01-05-2008, 12:52 PM
MtnHighTJ
MtnHighTJ's Avatar
yes it is, yes
Superwinch EPi 9000
Currie HD Tie rod
post #6 of 51 Old 01-05-2008, 01:12 PM
CHRRRIS
CHRRRIS's Avatar
The nuts on my drag link turn-buckle are so damn rusted, I PB Blasted 'em Thrusday night, 3 times yesterday, once this morning, and with a foot long, 1/2" ratchet with a deep socket, I can't get them to budge... what tools do you guys use? Are yours rusty? Mines a 10 year old Chicago TJ, so they're pretty bad, but I have had alignments before and they fixed the steering wheel before, but a local shop wants the $60 alignment fee to do it, so I walked away...
What to do... Air gun maybe? I know one guy who could help me there, but it'd cost maybe $20..
It's easier to go down a hill than up it but the view is much better at the top.
-Henry Ward Beecher
Current - '98 Black Z28 with some goodies
Previous - '97 Gun Metal Blue TJ
Northern Illinois Extreme Jeep Club
CHRRRIS is offline
post #7 of 51 Old 01-05-2008, 01:32 PM
MtnHighTJ
MtnHighTJ's Avatar
Mines not rusty, it's a new Currie HD drag link. I got it installed at a tire shop along with alignment and they returned it to me with the wheel off center. I didn't believe them so I went to adjust it myself and sure enough there is no more adjustment.
Superwinch EPi 9000
Currie HD Tie rod
post #8 of 51 Old 01-05-2008, 01:43 PM
Jerry Bransford
Administrator
They may have screwed up the installation of the drag link sleeve so the two sides of the drag link are not screwed in equally on both sides. Which is why I prefer doing that kind of work on my own.
post #9 of 51 Old 01-05-2008, 01:49 PM
MtnHighTJ
MtnHighTJ's Avatar
I'll check, but it's the opposite for me. When I try to do things that's usually when the trouble begins.
Superwinch EPi 9000
Currie HD Tie rod
post #10 of 51 Old 01-05-2008, 01:54 PM
djt283
djt283's Avatar
Use a breaker bar. 12" isn't that much leverage. If you don't have one, you could slip a pipe over your ratchet but that's a good way to kill the ratchet. Get something closer to 2' and you should be able to turn most things on the jeep. Unless it's really rusted and snaps...
djt283 is offline
post #11 of 51 Old 01-05-2008, 01:55 PM
JeSimmers
JeSimmers's Avatar
So messing with the draglink/steering wheel adjustment wont effect the $75 alignment I just had done?
JeSimmers is offline
post #12 of 51 Old 01-05-2008, 01:56 PM
Jerry Bransford
Administrator
Nope, it only affects the steering wheel's centering. And next time, do your own alignment using the above link in post #2 and save $75. The only two things that can even be done on your TJ is the toe-in which is VERY easy to do using that link, and centering your steering wheel. There's not much to a TJ's front-end aligment.
post #13 of 51 Old 01-05-2008, 01:57 PM
CHRRRIS
CHRRRIS's Avatar
No, you usually adjust the steering wheel after the alignment anyways..
-Henry Ward Beecher
CHRRRIS is offline
post #14 of 51 Old 01-05-2008, 01:59 PM
djt283
djt283's Avatar
Not to hijack this thread, but I'm under the impression that the only thing to adjust when aligning the front end is the toe-in/out. There's no way to adjust the camber as far as I know? It seems like a lot of people take it to a shop to have it aligned and I just want to make sure I'm not missing something.
djt283 is offline
post #15 of 51 Old 01-05-2008, 02:00 PM
Jerry Bransford
Administrator
Close. You always adjust (center) the steering wheel after the alignment.
Can I straighten my steering wheel myself? jjenkins11 TJ Wrangler Technical Forum 4 05-09-2008 02:25 PM
Straighten steering wheel his15153 TJ Wrangler Technical Forum 5 03-13-2007 11:31 AM
How do I straighten the steering wheel after a lift is put in? frank_frank139 TJ Wrangler Technical Forum 11 03-03-2007 05:51 PM
how to straighten steering wheel??? watkins 92 yj YJ Wrangler Technical Forum 7 07-21-2006 05:52 PM
Straighten Steering wheel? riesesdad YJ Wrangler Technical Forum 6 07-13-2005 06:46 PM
