How to spec and where to find non-OEM rubber bushings? - JeepForum.com
post #1 of 5 Old 11-06-2010, 03:13 PM Thread Starter
tw_jeep
Random thought...
Since 1) my tracbar axle mount is nicely wallowed out and 2) the few shops I contacted dont wish to drill out the tracbar bushing sleeve to accomodate a larger bolt...
I thought maybe i could find a similar bushing but with a larger diameter sleeve... such as I think Currie has in one of their tracbars and Clayton has in their HD tracbar (9/16" axle end bolt IIRC)
So how are these typically spec'd - at least dimensionally?
And where to find or order?
Parts houses seem to only have OEM ones in their computers. OReilly said if I came up with a part number, they could order it.
I'd prefer rubber as in the OEM style but a polyurethane one might work too.
Thanks
2000 TJ Sport/auto/D44/X8000i & Tomken mount/jeeperman rear bumper and rails/Skidrow steering skid/RE 3.5SF/33x10.5x15ATKOs/JB Conversions SYE/CV shaft/BESTOP tire carrier/AtoZ front bumper/Front Aussie Locker/some aesthetic stuff/
tw_jeep is offline
post #2 of 5 Old 11-06-2010, 03:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by twichers View Post
Random thought...
Thanks
Get one from the frame side of a JK front Trackbar or IIRC the frame side of a TJ rear trackbar is also 14mm and the same size on the OD.
Clayton is using the one from a JK or I'm pretty sure they are. 14mm = 9/16's or within 10 thou or so.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #3 of 5 Old 11-07-2010, 06:01 AM Thread Starter
tw_jeep
Thanks mrblaine.
I didnt realize that the JK front tracbar or the TJ rear were dimensionally similar to the OEM TJ tracbar bushing.
tw_jeep is offline
post #4 of 5 Old 11-07-2010, 08:14 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks mrblaine.
The lower end of the JK bar is not the same, it's narrower in width.
I've not looked at the axle side of a TJ rear trackbar with the intent of swappig bushings into something else, just the upper end because that's the end I usually wind up modifying.
I am Savvy
post #5 of 5 Old 11-07-2010, 11:13 AM Thread Starter
tw_jeep
Thanks for emphasizing that it's the frame end for both... I'll have to remember that... and see if I can get dimensional specs to help verify...
tw_jeep is offline
Rear Sway Bar Bushings (rubber) JeepNE TJ Wrangler Technical Forum 2 10-30-2010 12:29 AM
RE rubber bushings lax17 TJ Wrangler Technical Forum 8 07-17-2006 12:34 PM
How do I find out all of my spec.'s rem280 TJ Wrangler Technical Forum 5 06-07-2006 07:23 AM
Rubber Bushings On Valve Cover dazed TJ Wrangler Technical Forum 1 05-20-2005 09:32 AM
Vibrating rubber bushings? Trroper TJ Wrangler Technical Forum 2 11-05-2004 03:26 PM
