How to Reset the computer (Check engine light)? - JeepForum.com
post #1 of 4 Old 06-27-2004, 01:54 PM Thread Starter
BNovak
BNovak's Avatar
Just installed a new TPS as my engine threw out the code (Thanks Autozone!)
How do I reset the computer to get rid of the light now?
Thanks.
--BN
BNovak is offline
post #2 of 4 Old 06-27-2004, 02:07 PM
steveinmedford
steveinmedford's Avatar
2014 KL Cherokee
Disconnect battery for about 5 mins.
Steveinmedford
2014 KL, Cherokee Latitude, 2.4, auto
steveinmedford is offline
post #3 of 4 Old 06-27-2004, 02:11 PM
thecarman
That or plug the computer harness into a code reader and delete it with that.
I'd elect with the disconnecting of the battery.
1994 Jeep Wrangler 2.5L (White)
thecarman is offline
post #4 of 4 Old 06-27-2004, 03:54 PM Thread Starter
BNovak
BNovak's Avatar
So Back to autozone I go only to find out they don't actually reset trouble codes, only diagnose them....even after buying new parts there!
Anyway, I go outside, turn the jeep back on and low and behold, no more check engine light. Apparently it resets itself after two or three On-off cycles.
Thanks Guys.
--BN
BNovak is offline
check engine light...need a new computer? nonnaca TJ Wrangler Technical Forum 8 07-26-2009 12:29 PM
Is there a way to reset "check engine" light? wildbadbill YJ Wrangler Technical Forum 8 05-01-2009 11:56 AM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 10:28 PM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 07:45 AM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 09:59 AM
