how to reset check engine light - JeepForum.com
 1Likes
post #1 of 24 Old 02-18-2010, 01:55 PM Thread Starter
dawgknight
how do you reset check engine light so i can see if i have fixed the problem?
dawgknight is offline
post #2 of 24 Old 02-18-2010, 01:56 PM
mdm
Farm Wheeler
Disconnect the battery for a few moments.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 24 Old 02-18-2010, 01:56 PM
BWFBezerk
Drive it for 20 miles or so to see if it goes away, resetting it does nothing. If the problem is fixed the light will go out, a lot sooner than if you reset it and drove the 50+ miles to have the computer cycle.
BWFBezerk is offline
post #4 of 24 Old 02-18-2010, 01:58 PM
Yury
well i use the scanner tool. i heard if you pull the cable off the battery for a bit it should reset it. also if you fixed the problem it goes away after about 500 miles or so.
hope this helps
Yury is offline
post #5 of 24 Old 02-18-2010, 01:59 PM Thread Starter
dawgknight
thanks. i must have a couple of bad 02 senser. code p0155 and p0135. local shop thought they had fixed the problem header bolts were not tight. light went off but now it is back on. at roughfly 100 bucks apiece i hate to buy them if i do not have to
post #6 of 24 Old 02-18-2010, 01:59 PM
Yury
they beat me to it. also dont forget if you reset it with a scanner tool and you go to get inspected they can see that you did it and might fail you. at least here in new york they will
Yury is offline
post #7 of 24 Old 02-18-2010, 02:00 PM
BWFBezerk
hope this helps
I hope that 500 was a typo lol
post #8 of 24 Old 02-18-2010, 02:02 PM Thread Starter
dawgknight
fyi anybody thinking about a supercharger? this one seems to help alot. it is not something i would have spent money on but it was already on the jeep.i do think it plays havic on the computer sytem even with the unichip
post #9 of 24 Old 02-18-2010, 02:03 PM
Yury
sorry i meant less i realized that i was doing something else and for some reason the number stuck in my head. lol
long day
Yury is offline
post #10 of 24 Old 04-20-2010, 08:43 PM
dukemantee
I also had the check engine light re-appear after using a scanner tool....
I got a warning related to O2 system..but the previous owner of the jeep says it's the gas cap.... I've had mechanic check it out, and everything looks fine.
Has anyone experienced a similar issue because of the gas cap?
I am worried because I may sell the jeep at some point, and this could potentially scare people off.
dukemantee is offline
post #11 of 24 Old 04-20-2010, 09:10 PM
Yury
you can get a check engine light if your gas cap is loose. its not the same one as the 02 sensor i believe. IIRC its something like check emissions system or something of that nature.
Yury is offline
post #12 of 24 Old 04-20-2010, 09:13 PM
cpleasant
cpleasant's Avatar
Evap system for the gas cap.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #13 of 24 Old 04-20-2010, 09:34 PM
dukemantee
i've checked if it's loose....the light does come and go....
do you know if an aftermarket gas cap can fix this?
Maybe i can get the official 2007-2010 model jeep gas cap from mopar if it fits...
I like that it requires a key to open the cap.
post #14 of 24 Old 04-20-2010, 09:57 PM
Yury
yeah thats it
Yury is offline
post #15 of 24 Old 04-21-2010, 03:44 AM
cpleasant
cpleasant's Avatar
Don't waste your money like I did in buying a non-factory gas cap. Mine went from a small leak code to a large one when I did that.
The only thing that fixed my evap leak was the correct OEM gas cap. Jeep Wrangler accessory and original Jeep parts and accessories - only from Jeepsareus.com has them, but they are a little pricey. You may be able to find cheaper.
Is there a way to reset "check engine" light? wildbadbill YJ Wrangler Technical Forum 8 05-01-2009 11:56 AM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 10:28 PM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 07:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 03:54 PM
Check Engine Light reset skatedork TJ Wrangler Technical Forum 16 06-19-2003 09:59 AM
