How to replace starter? - JeepForum.com
post #1 of 18 Old 07-12-2009, 02:57 PM Thread Starter
stockpile
stockpile's Avatar
Just did a search, but could not find any start to finish write ups on how to replace a starter on a Rubicon. Basically, I will guess it goes something like this...
- Disconnect battery
- Disconnect wiring from starter
- Unbolt and remove old starter / solenoid
- Mount and bolt new starter / solenoid
- Connect wiring
- Reconnect battery
Hopefully I am not biting off more than I can chew. Since I cannot find a write-up, I assume that is because it is very straight forward? The hardest part looks like it will be getting my big hands in there to twist the bolts .
stockpile is offline
post #2 of 18 Old 07-12-2009, 02:58 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's just as easy as you described though I wouldn't bother disconnecting the battery for this particular job.
Getting
Jerry Bransford is online now
post #3 of 18 Old 07-12-2009, 03:00 PM
skipwheat
that about sums it up ive never had the pleasure of doing it on a jeep but ive replaced several starters on a bunch of old ford, chevy and dodge's i would imagine with as much room as there is all around the motor it shouldnt be too much of a hassle usually about the time it takes to drink a couple beers and your done happy wrenching
skipwheat is offline
post #4 of 18 Old 07-12-2009, 03:03 PM
03rubiconMG
it takes me about 25 minutes to change over a starter. it is very very easy.
2003 white rubicon on 37s
03rubiconMG is offline
post #5 of 18 Old 07-12-2009, 05:20 PM Thread Starter
stockpile
stockpile's Avatar
Thanks, that was an easy job. Removing the + cable was a bit tricky due to some rust on the bolt and negotiating the exhaust pipe and oil pan with my socket. Some penetrating fluid would have helped, but no big deal in the long run, just wasted a few minutes extra on that. Installing the new one took a matter of minutes and my TJ started right up .
post #6 of 18 Old 07-12-2009, 08:26 PM
tangofox007
Originally Posted by Jerry Bransford View Post
...though I wouldn't bother disconnecting the battery for this particular job.
There happens fo be a positive cable that connects the battery to the starter. It is hot at all times. If you happen to touch your wrench to ground while disconnecting said cable, I suspect you that you will wish that you had disconnected the battery.
A fellow that I used to know received third degree burns around his wrist and required surgery when his metal watchband created a ground path between the starter solenoid terminal and the engine block while doing this very job.
tangofox007 is offline
post #7 of 18 Old 10-16-2010, 01:17 PM
reondadomino
Just bought an 88 Jeep Wrangler and am trying to replace the starter. I have everything disconnected but am not sure about which bolts to remove.
There are 2 on the bottom of the starter, which I think go to a bracket above it and hold it in place. However, every pic I've seen shows the bolts being removed horizontally from the front/side of the transmission. I see those bolts but they don't look like they connect to the starter at all. They look like transmission case bolts and they are pretty big...
Any suggestions? I don't wanna do more than I have to, lol, it's pretty rusty underneath there
reondadomino is offline
post #8 of 18 Old 10-16-2010, 01:39 PM
reondadomino
Anyone?
post #9 of 18 Old 01-09-2011, 10:36 PM
nhlx38
same issue here!
nhlx38 is offline
post #10 of 18 Old 01-09-2011, 10:54 PM
Alkaline
Look at the new starter, and how it bolts on, that should tell you everything you need to know...
☠ ʎɐqə ɯoɹɟ pɹɐoqʎəʞ ɐ ʎnq ı əɯıʇ ʇsɐl əɥʇ sı sıɥʇ ☠
'98 TJ (toy), '91 XJ Briarwood(DD)
Alkaline is offline
post #11 of 18 Old 01-09-2011, 11:19 PM
RckyMtnTJ
One bolt comes through the starter into the transmission. The other comes from the back through the transmission and into the starter.
98 TJ with some stuff
RckyMtnTJ is offline
post #12 of 18 Old 01-09-2011, 11:55 PM
BigD97TJ
It's an easy job. Just did it the other day.
Now 30 minutes? I don't know about that but I also stripped the upper bolt that threads into the starter torquing it to spec so I had to get a replacement.
BigD97TJ is offline
post #13 of 18 Old 01-10-2011, 12:02 AM
austentatious
Shoot, replacing a starter shouldnt take more than ten min...its incredibly easy. Easier than taking the top on and off.
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #14 of 18 Old 01-10-2011, 12:50 AM
BigD97TJ
Well I do consider myself half retarded.
I found that the bolts were a little difficult to get and since I have a leak everything is covered in crap down there.
I don't disagree with the fact that it's possible to do in ten minutes, next time I'll just have you do it and I'll supply the beer
BigD97TJ is offline
post #15 of 18 Old 01-10-2011, 12:51 AM
RogueSpear2023
This is one of the reasons why no matter what repairs you are doing you should always remove all jewelry before working on vehicles, I have heard this same thing happening with peoples wedding bands. Also getting a piece of Jewelery stuck on something can cause all sorts of problems, my uncle nearly lost his finger working on a boat because his wedding band got hooked on something and the boat was in motion.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
About to replace the starter stilltippin YJ Wrangler Technical Forum 11 01-17-2009 10:37 PM
When to replace starter? Jeepeiro TJ Wrangler Technical Forum 25 01-07-2009 03:45 PM
should i replace the starter? mean90yj YJ Wrangler Technical Forum 10 03-20-2007 11:09 AM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 01:34 PM
Replace Starter $370? bjsbuds YJ Wrangler Technical Forum 10 01-24-2005 02:27 AM
