How to replace freeze plugs? - JeepForum.com
post #1 of 11 Old 02-21-2011, 11:09 AM Thread Starter
Goalie990
My sisters jeep is leaking coolant out of some of the freeze plugs. I have not see what ones yet but I want to ask you guys what it takes to replace them. I am mechanically inclined and can replace them but want to know if you have to remove the motor or what? Any info would help.
Goalie990 is offline
post #2 of 11 Old 02-21-2011, 11:14 AM
athos76
Last time I replaced a freeze plug, we soaked it in PB blast for a bit to loosen it, then ran the engine to warm everything up, more PB and a little torch action. Then using a good quality hex socket and some valve grinding compound on the tip, tap it in with a hammer and slowly loosen it. If it gets too tight, PB and torch it again. When you put it back in, a little Tite Seal or non hardening gasket compound will do wonders
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #3 of 11 Old 02-21-2011, 11:19 AM Thread Starter
Goalie990
All that to get a freeze plug out? I figured you could just stab it with some thing and yank it out. Was just wondering about the location of them and how hard they are to get to.
post #4 of 11 Old 02-21-2011, 12:01 PM
JeffBowser
I had my rear freeze plug replaced a few years back. Went from a quick one hour job to an all day job when they had trouble getting the new one to seal. They ended up going through a couple of them, and using a non-hardening compound. It was hard to get to, but they managed without pulling the engine.
JeffBowser is offline
post #5 of 11 Old 02-21-2011, 12:17 PM
athos76
D'oh... Freeze plug that took that amount of work was on a Turbo Diesel... Forgot heeps have the other kind...
Yea, stab it and pull it out...
athos76 is offline
post #6 of 11 Old 02-21-2011, 12:24 PM Thread Starter
Goalie990
Just wondering but what diesel took that long? My cummins is the same as the jeep. I put billet freeze plugs in my cummins. How many freeze plugs are there total on the jeep and what are the locations?
post #7 of 11 Old 02-21-2011, 01:17 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
5 along the driverside under the manifolds and 2 in rear and 1 on the head.
GOLENJEEPTJ is offline
post #8 of 11 Old 02-21-2011, 01:18 PM Thread Starter
Goalie990
So with the manifold off you should be able to get to the one on the side and i hear to use a rubber expanding plug for the rear if I dont want to pull the motor. What size rubber plug for the rear?
post #9 of 11 Old 02-21-2011, 01:29 PM
GOLENJEEPTJ
It might also help to know the year and engine.
post #10 of 11 Old 02-21-2011, 01:36 PM Thread Starter
Goalie990
opps its a 6cylinder and its a TJ donno the exact year id have to ask.. i think 98 or 99. They are the same for quite some time tho right?
post #11 of 11 Old 10-12-2015, 06:20 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Freeze plug thread #4 replied to by RockCzar today.
TheBoogieman is offline
Bad Freeze Plugs jcook1989 YJ Wrangler Technical Forum 3 06-02-2008 09:35 PM
Freeze out plugs angryjohnny TJ Wrangler Technical Forum 5 09-23-2007 10:24 PM
Freeze Plugs jeff421 TJ Wrangler Technical Forum 0 11-07-2006 10:01 PM
Freeze Plugs In 4.2L mellow YJ Wrangler Technical Forum 2 04-21-2006 10:57 PM
Freeze plugs!?!?!?! RayOvac YJ Wrangler Technical Forum 6 09-25-2003 04:04 AM
