How to remove rusted bolts? - JeepForum.com
post #1 of 5 Old 12-27-2009, 01:15 PM Thread Starter
danfrompa
2015 JK Wrangler
The bolts that are holding the driver and passenger seats to the floor are rusted. I don't think it will come out. Any suggestion of how it can be removed? Do I have to drill it or is there a simpler way to removed these rusted bolts? By the way, where do I get it removed if I want to have a professional do it? Thanks!!!
danfrompa is offline
post #2 of 5 Old 12-27-2009, 01:17 PM
Mark4883
Use a ton of PB blaster. Heat them up. Drill them out. Try them all, one will work.
Mark4883 is offline
post #3 of 5 Old 12-28-2009, 08:35 AM
shay4au
2010 JK Wrangler
I was going to suggest PB Blaster as well. My '01 had several rusted bolts that I couldn't budge. I went to Lowes and bought a 12" long piece of 1.25" galvanized steel pipe and used it as a cheater bar. Leverage works wonders!!! This is assuming you can get a ratchet & socket to the nut ofcourse...
shay4au is offline
post #4 of 5 Old 12-28-2009, 09:05 AM
JustChillin
what shay4au said. you can spray it a few days in advance to help a little. PB Blaster and a breaker bar works wonders.
JustChillin is offline
post #5 of 5 Old 12-28-2009, 09:12 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
PB blaster and a 1/2" drive ratchet.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
Removing rusted oil pan bolts??? ppandr YJ Wrangler Technical Forum 7 03-01-2010 11:40 AM
Removing B/L. All the !?$#@ bolts are rusted! danny2go YJ Wrangler Technical Forum 4 09-30-2008 08:55 PM
inspecting brakes. rusted hub. cant remove 9erHIGH YJ Wrangler Technical Forum 9 10-22-2006 10:04 AM
Help Removing Rusted Bolts? ddwyer YJ Wrangler Technical Forum 34 07-17-2005 08:56 PM
Rusted Bolts? jeepdan TJ Wrangler Technical Forum 3 08-14-2002 11:33 AM
