how to remove fender flares?? - JeepForum.com
post #1 of 21 Old 12-31-2008, 12:09 PM Thread Starter
badboy97tj
I know this sounds like an easy question but I went to remove mine today and it looks like there is a little insert that spins when I turn the bolt. Do I just grind the bolt off or is there another secret to do this ?
Thanks in advance!!
Josh
badboy97tj is offline
post #2 of 21 Old 12-31-2008, 12:13 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Hold it with needle nose pliers.
TheBoogieman is offline
post #3 of 21 Old 12-31-2008, 12:14 PM
jeepindirty
The last time I took mine of I had to use a wrench on one side while a turned the bolt with a another wrench. Whatever you do resist the urge to break out the grinder! Oh yeah and on the back you might have to bend the inner fender well plastic up and out of the way to get to the nut.
jeepindirty is offline
post #4 of 21 Old 12-31-2008, 12:15 PM Thread Starter
badboy97tj
Hello,
It is like there rusted enough where I can't hold them and there are some you can't get to.
Thanks
post #5 of 21 Old 12-31-2008, 12:16 PM
southernss
i tried the neddle nose pliers but i could not grip it tight enough to keep it from spinning. i ended up just putting enough force on it to pop the whole thing out crew and all. but i was not to worried about it either because the rocker gaurds would cove the hole it left anyway.
southernss is offline
post #6 of 21 Old 12-31-2008, 12:16 PM
slaphands
I just took mine off a couple days ago to paint them. I just held the back with my fingers and used a wrench on the nut.
Edit: The rear flares are hard, you either have to pull your wheel wells off, or pull them down enough to slide your hand or pliers in there to hold the back piece.
'00 TJ / 2.5L / Manual
"Stop tailgatin' me ya pasty teabag."
Low Output 4 Cylinder Jeep Club Member #313
Red Jeep Club Member #525
slaphands is offline
post #7 of 21 Old 12-31-2008, 12:17 PM Thread Starter
badboy97tj
There is no nut to get to!
post #8 of 21 Old 12-31-2008, 12:36 PM
southernss
correct! i believe you are talking about the small 12" flare below the door?
post #9 of 21 Old 12-31-2008, 12:53 PM
jeepindirty
Mine must be weird or something cause they were held on with bolts!
post #10 of 21 Old 12-31-2008, 02:22 PM Thread Starter
badboy97tj
yes, that is the piece I'm talking about.
post #11 of 21 Old 12-31-2008, 02:41 PM
Jeep25
BINGO!!!
That's what I did with mine and added a ton of extra work with drilling the screws out of the inserts.
Not fun.
Jeep25 is offline
post #12 of 21 Old 12-31-2008, 03:13 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You can push up on inner wheel well liner and hold the nutserts with a pair of pliers! It's pretty basic!
GOLENJEEPTJ is offline
post #13 of 21 Old 12-31-2008, 06:31 PM
Jim Shanks
Jim Shanks's Avatar
Are they going back on? If not, just yank them off. I had a couple spinning in my tub but I was putting crusher corners on so I just pulled. They will give and come over the bolts if needed.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #14 of 21 Old 12-31-2008, 06:37 PM
Jeepball
Try to back off the bolts just a little cuz that little peace slides off. Just pulll if you are putting on rocker guards. Just watch and make sure u dont pull the body out of wack.
HUMMER RECOVERY TEAM
Low Output 4 Cylinder Jeep Club member #173
Jeepball is offline
post #15 of 21 Old 12-31-2008, 06:50 PM
LARSONEM
I just replaced front fenders on my Jeep. The fender flares were a bear to get off. The majority of the screws have a plastic block on the back that I was able to hold with a pair of channel locks. There were 2 or 3 screws on the fender flare that went into a 6 sided insert that went into the fender under the fender flare. The screws were rusted (I have a 1997 Wrangler and live in Michigan where salt is the name of the game in the winter) into the insert so badly that all it did was turn the 6 sided insert in the hole in the fender. There was no way you could hold it with channel locks. Same was true for 2 of the 3 screws that hold the fender flare extension on. I ended up cutting them off with a sawzaw (very carefully - wished I had a small grinder or Dremmel tool). In remounting them, I used all new screws into the plastic blocks and used a screw/washer/nut on the last 2 or 3 fender flare screws. For the lower fender flare extension, I found some plastic wing nuts, much like a molly bolt and ground it down a little and hammered them into the lower cowl, then drove new screws into them. Those darn 6 sided inserts were like $5.00+ from the Jeep stealership, special ordered at that. A trip to my local hardware netted me something to put it back togeather with for less then $5 total.
Eric Larson
1997 Red Wrangler 4.0L - 5 speed - soft top w/full frame doors - 2 inch spring spacers and 1 inch body lift - 31 x 10.50 BFG on 15 x 8 Pro Comp 8069 rims
LARSONEM is offline
How do i remove my fender flares? baldingo1 YJ Wrangler Technical Forum 12 08-31-2011 09:38 PM
How best to remove stock fender flares? archer75 TJ Wrangler Technical Forum 29 12-09-2010 05:02 PM
How to remove fender flares? Leia7987 YJ Wrangler Technical Forum 8 08-01-2009 05:41 PM
How to remove the fender flares? GarageBoy YJ Wrangler Technical Forum 10 08-19-2006 07:44 AM
Should I remove the fender flares to paint them? Trroper TJ Wrangler Technical Forum 7 06-29-2004 09:41 PM
