How to remove bump stop & insert spacer? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to remove bump stop & insert spacer?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 08-23-2008, 02:03 PM   #1
TJamz
How the heck do I remove the bump stop to insert a spacer? There's a metal "ring" around the bumpstop metal part preventing me from sliding it on.
What's the trick?
TJamz is offline   Reply With Quote
Unread 08-23-2008, 02:05 PM   #2
flatlander757
Yank the rubber "bumper" out, you will see a bolt(I forget the size, I want to say 13mm or so) and undo that. The bumpstop "cup" will come right off then.
For the rubber bumper, I find it helpful to wiggle it back and forth with a lot of force as opposed to just pulling straight out, much easier.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote
Unread 08-23-2008, 02:33 PM   #3
TJamz
Sweet. Thanks!
