How reliable? - JeepForum.com
post #1 of 7 Old 12-12-2004, 05:59 PM Thread Starter
JakeJones
How reliable?
If I got 4.56's with my 33's how tough are they going to be. (no matter what brand of gears).
Has anyone ever had any problems with 4.56's if so how did it happen?
by the way i have a d44 .
Yellow 00 Sport RE 3.5" 33 FirestoneM/Ts
JakeJones is offline
post #2 of 7 Old 12-12-2004, 06:37 PM
FlexyTJ
FlexyTJ's Avatar
why? if the gears are intsalled properly there should be no problem.
MK Motorsport & Fabrication
FlexyTJ is offline
post #3 of 7 Old 12-12-2004, 06:58 PM Thread Starter
JakeJones
yeah but if there is no 4wd stores around where can i take and be sure it's installed properly?
post #4 of 7 Old 12-12-2004, 07:06 PM
doorocks
doorocks's Avatar
First off, if you are doing this on your own and have not done this before......you need to think twice or get some experienced help.
You do not need a 4wd shop to install/check R&P....a speed shop, hot rod shop, axle shop, truck shop and some garages have certified mechanics who do this.
Look in the superpages.com
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #5 of 7 Old 12-12-2004, 07:16 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
If I got 4.56's with my 33's how tough are they going to be. (no matter what brand of gears)...
Brand of gears can play a factor in how durable they will be. I like to use OE parts with my axles. They cost a little more, but IMO, it's well worth it when the labor for the job is so expensive.
Wheelin98TJ is offline
post #6 of 7 Old 12-12-2004, 07:28 PM Thread Starter
JakeJones
anything like that around here is like the small mom & pop shop.
South Mississippi.
post #7 of 7 Old 12-13-2004, 06:50 AM
jeeptoplesstx
jeeptoplesstx's Avatar
It would probably be worth it to drive a few hours then to a good shop...I looked into doing this myself a year or so back with the 03 TJ...you need a bunch of specialized tools number one that will set you back a good amount...and from everything I researched you just dont want to try it on your own...you will have nothing but problems...most shops wont even let most of the mechanics do gears...they normally only have one or maybe two guys that are qualified to do them...So, unfortunately you are gonna have to drive is what it sounds like...but as to your original question...a properly installed new set of gears shouldnt give you any trouble whatsoever...they should be just like factory except better suited for your tire size...
2004 Jeep Wrangler Rubicon
jeeptoplesstx is offline
The TJ reliable? MasterCujo TJ Wrangler Technical Forum 74 05-15-2010 11:01 PM
Which is more reliable, '04-'05 JGC or '02-'04 TJ? jmwilson Wrangler General Discussion 11 02-12-2010 12:26 AM
How reliable? vjz YJ Wrangler Technical Forum 39 07-18-2009 08:13 PM
O2 Sensors...how reliable??? Yesfan70 TJ Wrangler Technical Forum 1 12-07-2006 05:39 PM
4 cyl Reliable? 8inchXJ YJ Wrangler Technical Forum 19 02-10-2005 09:29 PM
