How to pull axle shafts on D60 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to pull axle shafts on D60
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 02-01-2012, 09:36 AM   #1
Usmcmach1
Ladies/Gents-
So I just got my brand new Dana 60 out of the box and ready to go. Except one thing, I am reusing my rear drums, so I realized I had to pull my shafts out of my 35 to get the drum assy off. That was easy enough, but how do I pull the shafts on the Dana 60?
Ps it's a Rockjock 60 with ARB
Usmcmach1 is offline   Reply With Quote Quick reply to this message
Unread 02-01-2012, 09:49 AM   #2
mdm
Farm Wheeler
You're going to use the D35 drums on the D60?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 02-01-2012, 09:50 AM   #3
maximus1000
Should just have the 4 bolts on the flange. Ill get a pic for you in a sec
maximus1000 is offline   Reply With Quote Quick reply to this message
Unread 02-01-2012, 09:51 AM   #4
Ripper3494
i wouldnt trust the 35 brakes to even stop the axle shafts of a 60 from spinning lol. my 35s brakes suckeedddd
build thread:
[url]http://www.jeepforum.com/forum/f22/94-yj-6-0-build-spud-1218315/[/url]
1997 ZJ limited - BONE stock
[url]http://www.jeepforum.com/forum/f12/alternator-welder-write-up-1301614/[/url]
[url]http://www.jeepforum.com/forum/f12/tj-uppers-yj-half-doors-hard-top-installation-1417686/[/url]
RC vs BDS
[url]http://www.jeepforum.com/forum/f12/rough-country-vs-bds-1461555/[/url]
Ripper3494 is offline   Reply With Quote Quick reply to this message
Unread 02-01-2012, 09:51 AM   #5
maximus1000
This is my 60 flange.
Unread 02-01-2012, 09:53 AM   #6
Usmcmach1
Sorry for not using correct terms but... I can't slide them over the outer flange (where the wheel studs are) unless that piece comes off? It seems that they have to go on before the axle shaft assy slides in?
Unread 02-01-2012, 09:56 AM   #7
Usmcmach1
Maximus-- yeah that seems to be the place where I need to get to. But my axle came with the shafts in. Am I correct that your picture was with the shafts out. Sorry a complete noob here, winging it.
Unread 02-01-2012, 10:01 AM   #8
maximus1000
Yeah thats with the shafts out and the drum brake backing plate off. I converted it over to disc brakes.
Unread 02-01-2012, 10:04 AM   #9
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The rear brakes don't have much braking responsibility, they only provide 20-25% of the total braking force. The D35 brakes are the same brakes used by the D44.
Offroad until Sunday!
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 02-01-2012, 10:05 AM   #10
Usmcmach1
So then just to recap... The shafts have to be out to install the drum mount plate? If so how do I pull the shafts? ( which will be done with tears streaming down my face, I really don't want to take apart a new assy)
Unread 02-01-2012, 10:10 AM   #11
maximus1000
Yes, you have to install the drum backing plate first, then the axle then the retainer plate. If its a 60 then it should be a semi float, once you remove the retainer plate, the axle should slide right out.
Unread 02-01-2012, 10:12 AM   #12
Jerry Bransford
Administrator
No, the shafts have to come out. Four bolts hold them in via the shaft retainer plate. Once the retainer plate is off, just pull the shafts straight out.
Getting Savvy...
Unread 02-01-2012, 10:15 AM   #13
Usmcmach1
Retainer plates are at the ends? Nothing in the the diff needs to be touched?
Unread 02-01-2012, 10:18 AM   #14
maximus1000
Yep, retainer plates are on the inside of the drum -so esentially what you have is the retainer plate and the flange (pictures above) sandwiching the drum backing plate.
Unread 02-01-2012, 10:20 AM   #15
Usmcmach1
Awesome!!! Thanks for all the quick replies and help.
