How to plug hole for air locker in Rubi housing? - JeepForum.com
post #1 of 5 Old 08-30-2005, 05:15 PM Thread Starter
DesertX04
I was planning on just using a self tapping bolt, just got to find the right size. Any ideas from those that have used this housing for an axle swap and not used air lockers? Thanks.
Alan
2004 X, 35's, Locked, Superwench, other stuff
DesertX04 is offline
post #2 of 5 Old 08-30-2005, 05:26 PM
BNovak
BNovak's Avatar
If you are tearing the whole axle apart and can clean out shavings from the inside, I'd say thread the hold and then put a bolt in it. This way, if you ever add an air locker or other actuated locker, you can just pull the bolt and not worry about having weird threads in the housing.
If you are NEVER going to use a locker, jusst stick a self tapper in there and you should be fine (I'd still thread it though, IMO.)
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #3 of 5 Old 08-30-2005, 05:30 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If you know it's truly permanent, I would just use JB-Weld epoxy.
Jerry Bransford is offline
post #4 of 5 Old 08-30-2005, 06:38 PM Thread Starter
DesertX04
I did want to keep it available for the future, but it's tight area, a PITA and I've always wanted to use JB Welb. One step closer, thanks guys.
post #5 of 5 Old 08-30-2005, 07:03 PM
cincytj
cincytj's Avatar
you could buy a vacuum cap at Autozone. Then its nothing permanent. If your worried about it coming off put a clamp on it.
03 Patriot Blue Sport
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
cincytj is offline
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
Rectangular hole in drivers side top of bell housing. Does it need to be plugged? spshultz YJ Wrangler Technical Forum 4 07-08-2008 06:40 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
Extra hole in new D44 housing? AnotherRED TJ Wrangler Technical Forum 20 10-30-2007 10:43 AM
Help...Rubi D44 Housing Plugs Viet15philong TJ Wrangler Technical Forum 11 12-14-2005 12:48 PM
