how often should 4WH be engaged? - JeepForum.com
post #1 of 12 Old 07-14-2010, 04:47 PM Thread Starter
billabong266
I live in Florida so i don't do much off-road driving. Since i never use 4WH or 4WL should i engage it maybe once a month to keep everything in good order? I know not to engage on dry pavement; i can take it on the beach.
billabong266 is offline
post #2 of 12 Old 07-14-2010, 04:50 PM
freeskier93
It won't hurt to engage it rolling straight down the pavement, it's turning that puts stress on the drivetrain.
I also wouldn't worry about it, the T-case is full of lube so nothing is going to seize. It's just a big *** chain that drives the front wheels so that's not going to break either.
freeskier93 is offline
post #3 of 12 Old 07-14-2010, 07:37 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
All the parts are turning, even in 2WD...
Knuckelhead is offline
post #4 of 12 Old 07-14-2010, 08:09 PM
tjkj2002
2002 KJ Liberty
Yeah but the shifting mechanisms can still seize.
It's always good to shift into 4wd at least once a month and drive around for a few mins,keeps the shifting smooth.
Oh and even in a straight line you will have binding in 4hi/4low unless you have D44's F/R or D60's F/R,different F/R axles(D30/D35) will have slightly different gear ratios and will cause binding even when going straight.
tjkj2002 is offline
post #5 of 12 Old 07-14-2010, 09:06 PM
danielbuck
1946 CJ2
I've wondered about this. the previous owner of my jeep probably never shifted to even 4hi, muchless 4lo. The first few times I engaged them (4lo in particular) there was some noises. After the first few times however, I've never noticed any of the noises. It may be that I'm subconsciously doing it different after the first few times. But I was assuming that it was because it had not been engaged in a while. Now that I'm engaging it every week or two when I'm off road, it doesn't make any more noises.
Don't know if that's because i've subtly changed my technique of engaging (speed of the jeep I guess?) without knowing it, but it seems to be better now.
And also, the first few times i engaged 4lo, I noticed a strong smell (kind of like a clutch or brake pad smell, but I can't be sure?) that I don't notice anymore when I engage it now. I'm guessing this is probably because at that time I might have been using the clutch more slowly and tapping the gas more than I do now. I think now I'm popping the clutch out quicker and not using any gas when I start out from a stop in 1st, 2nd, or 3rd when I'm in 4lo because I've found hitting the gas and "riding" the clutch a little bit is not needed with such a low gear. I may have (by instinct) used a bit of gas and a slower clutch pull the first few times I started out from a stop in 4lo, as I was not used to such a low gearing ratio.
Strange how quickly my body/mind adjusts to new variables, 2 months ago my only car was a 650+hp mustang, and now I'm in a slow 4wd jeep, I've had to make some adjustments, and I suspect I've adjusted more (subconsciously) than I think I have! (and loving every minute of it)
danielbuck is offline
post #6 of 12 Old 07-14-2010, 09:25 PM
monkeygruven
a related question from me. when i go to shift into 4LO, it grinds. i've tried rolling at 2-3MPH, tried it in neutral, still grinds. only way i can get it to properly engage is shutting off the engine while the 42rle is in neutral, shifting into 4LO, and restarting the engine. anybody else ever have this happen to them? should i shift into 4LO more often to help prevent this?
Originally posted by MotoSoul:
The real trail rated badges are located on your skid plates.
monkeygruven is offline
post #7 of 12 Old 07-14-2010, 09:30 PM
bs1946
I wait for a heavy rain and then put the Jeep in 4Hi for a while. Less chance of scrubbing the tires on wet pavement.
bs1946 is offline
post #8 of 12 Old 07-14-2010, 10:34 PM
freeskier93
Oh give me a break, your axles aren't going to assplode driving in 4wd for a couple hundred feet.
post #9 of 12 Old 07-14-2010, 11:05 PM
tjkj2002
2002 KJ Liberty
Seen it happen in less the 10 feet,granted the t-case had helical cut gears and could not be driven in reverse while in 4low but idiots still did it.Blew the t-case in 5 pieces everytime.
Your axles will survive but your t-case chain and/or case does not like it.
tjkj2002 is offline
post #10 of 12 Old 07-15-2010, 01:06 AM
BYuen
BYuen's Avatar
Try coming to a complete stop in neutral then try shifting into 4Lo. Shifting it more often into 4Lo won't solve your problem. If it's still grinding, the Tcase might not be engaging all the way. You could adjust your shifter linkage.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #11 of 12 Old 07-15-2010, 01:12 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
this doesnt really hold any water. gears are less forgiving than chains. the chains in the 231 and 241 Tcases in our TJs will stretch and give or even break before the case itself blows apart.
nobody is stupid enough to drive in 4hi with different sized tires or different gears front and rear. 4.10=4.11, 4.88=4.86. different axles and "different" gear ratios wont matter.
Mail crawling.
MisfitSeven is offline
post #12 of 12 Old 07-15-2010, 04:41 AM
RogueSpear2023
Your not going to hurt anything driving in 4hi on pavement as long as you don't turn, the very slight difference in gear ratios is not enough to make a difference. Your talking about a thousandths of an inch at most, even with a D30/D35, or D44/D44, they are matched pretty close.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
tj , tj wrangler , wrangler , 4wd , engage , 4wh , beach , inactivity
1/2 of lug engaged bean66 TJ Wrangler Technical Forum 18 03-03-2010 04:34 PM
4wd not sure if engaged klincker TJ Wrangler Technical Forum 18 12-20-2008 12:15 AM
4wd won't stay engaged smhammen TJ Wrangler Technical Forum 5 04-24-2006 07:52 AM
Is 4wd engaged JPJeeper YJ Wrangler Technical Forum 4 12-28-2005 04:08 PM
4wd engaged? JPJeeper YJ Wrangler Technical Forum 5 12-21-2005 09:45 PM
