How often do you check your u joints? - JeepForum.com
post #1 of 16 Old 01-30-2014, 03:50 PM Thread Starter
marlowequart
I read on stus jeep site that he reccomends taking apart and checking/greasing the u joints as part of the regular maintenance, but I was wondering how often most people do this?
marlowequart is offline
post #2 of 16 Old 01-30-2014, 03:57 PM
2jhanna
If it was necessary to take apart and grease, I would just replace them with grease able u-joints with zert fittings.
jhanna
denton county, tx
2jhanna is offline
post #3 of 16 Old 01-30-2014, 03:59 PM
flying2275
"The squeaky hinge gets the grease".
I don't touch them until they become a problem. Pulling them apart to clean and re-grease just isn't worth it for me. I do however keep spares on hand.
flying2275 is offline
post #4 of 16 Old 01-30-2014, 03:59 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I check mine when/if I hear clunking.
TheBoogieman is offline
post #5 of 16 Old 01-30-2014, 06:28 PM
blubaru2002
I just replaced all my u-joints on my front axle last weekend. I had the front driveshaft out bc I got angry sparrows. Upon inspection, it turns out the centering ball had wallowed out its sleeve. I replaced the centering ball as well.
All the u joints still have the original grease in them and were in working order. However I replaced them with brand new greasable u-joints. I figure at 123,000 miles, it's not a bad idea.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #6 of 16 Old 01-31-2014, 09:52 AM
Leffnasty
Originally Posted by blubaru2002
I just replaced all my u-joints on my front axle last weekend. I had the front driveshaft out bc I got angry sparrows. Upon inspection, it turns out the centering ball had wallowed out its sleeve. I replaced the centering ball as well. All the u joints still have the original grease in them and were in working order. However I replaced them with brand new greasable u-joints. I figure at 123,000 miles, it's not a bad idea.
I've been wondering the same as OP. Probably going to replace mine soon, seeing as 115k can't be good to them. Where did you get these greasable ones (part no.)?
Leffnasty is offline
post #7 of 16 Old 01-31-2014, 10:12 AM
stump1
depends on how big your tires are or how hard you wheel.
ive run stockers that ive checked yearly
now i run big tires on relatively small axles so i check them monthly(or anytime im wrenching under there really just cuz..)
i feel there is a basic maintenance if you wheel your jeep regularly and im always tinkering when it comes to these things like trackbar tighness, jam nuts coming loose off my currie ca's, retourqing things like lugs and such
MY RIG: http://i78.photobucket.com/albums/j87/ramburger/a0fcb769-5e55-4a62-8426-cb7cce41c0c2_zpsccea3c78.jpg
stump1 is offline
post #8 of 16 Old 01-31-2014, 10:32 AM
blubaru2002
Napa. IIRC they sell sealed and greasable models for both the cv u joints and the front axle side u joint.
post #9 of 16 Old 01-31-2014, 10:35 AM
Zombi
x2 or a nasty vibe.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #10 of 16 Old 01-31-2014, 07:17 PM Thread Starter
marlowequart
Sweet, thanks for the info.
post #11 of 16 Old 01-31-2014, 07:53 PM
trickydick
I just replaced my front drive shaft front U joint when it started making noise, cheap POS only lasted 145,000 miles. I went with the grease-able kind from Orielly's .
trickydick is offline
post #12 of 16 Old 01-31-2014, 08:21 PM
2jhanna
At 145k miles, should still be under warranty.
Can't trust anything these days.
jhanna
denton county, tx
2jhanna is offline
post #13 of 16 Old 01-31-2014, 08:42 PM
hustler905
Thanks to this thread I dropped my skids and greased my front driveshaft and all the other Zerks while I was at it! Thanks for giving me a thing to compulsively check!
hustler905 is offline
post #14 of 16 Old 01-31-2014, 09:05 PM
MuddyJeepZJ
MuddyJeepZJ's Avatar
www.drivetrainamerica.com/ Do yourself a favor and buy some spicer stuff unless you really like changing them all the time. There is a reason the stock ones last 145,000 miles.
2004 Jeep Wrangler Rubicon
2003 Dodge Ram 3500
MuddyJeepZJ is offline
post #15 of 16 Old 01-31-2014, 10:39 PM
Necko2529
Necko2529's Avatar
Damn Jeep, should have never chose Spicer, 145K is laughable!!! Chinese made parts-house brand should have been there from the get go.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
