How Often do you Change your Fluids? - JeepForum.com
post #1 of 28 Old 11-02-2008, 09:38 PM Thread Starter
TJShadow
I'm just starting to learn more about working on my Jeep, and I'm wondering how often everyone changes their fluids i.e. oil, transmission, radiator, differential, brake, steering, etc., and which fluids you recommend. Do you go by the factory maintenance schedule, let a few things slide, or do you change some fluids more than what the manual calls for?
TJShadow is offline
post #2 of 28 Old 11-02-2008, 10:09 PM
JBStone
I'm at 18,500K miles on my Rubi so far and here's the schedule I'm on:
1. Engine Oil (Mobil 1 Synthetic) Every 5K Miles
2. Engine Oil Filter (Mobil 1) Every 5K Miles
3. Air Filter Every 5K Miles
4. Rotate Tires (5 Tire Rotation) Every 4K Miles
5. Differential Fluids Every 12K Miles (Switching Back to Non-Synthetic Per Jerry Bransford's Post From a While Back)
As far as the other stuff goes, I'll probably stick with the maintenance schedule per the owner's manual unless I see otherwise from the great people on this forum.
JBStone is offline
post #3 of 28 Old 11-02-2008, 10:12 PM
GREASEMONKEY
I use all AMSOIL fluids, and filters.
Oil @15K
ATF @60K
Transfer Case @60K
Differentials @60K
The air filter gets cleaned @5K
Rotate tires @5K
Got EBC Green brake pads Ft & Rr with 40K on them, and half the media left!
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
post #4 of 28 Old 11-03-2008, 10:25 AM Thread Starter
TJShadow
Oil @15K
ATF @60K
Transfer Case @60K
Differentials @60K
Rotate tires @5K
I've heard a lot of people mention that they like AMSOIL, but do you really only change your oil every 15k? My jeep was a lease before I bought it, and I probably only changed my oil about every 15k too (with synthetic), but I was wondering if I should have changed it more often. Oddly, I thought that I could tell when my Jeep really needed fresh oil, and it did seem to drive better afterwards.
I also didnt change my differential fluid untill about 50k due to a regear, but the manual has it listed that you should change it every 12k - is that excessive or should I start doing that with my new gears?
TJShadow is offline
post #5 of 28 Old 11-03-2008, 10:40 AM
GREASEMONKEY
Amsoil oil, with the Amsoil filter is listed on their site at 20k intervals!
12k on factory fluid is fine, but over kill with the top quality lubricants.
post #6 of 28 Old 11-03-2008, 10:57 AM
robertdeal
change your fluids every 5000 miles or if you dont run 5000 in 3 months change it every 3 months
robertdeal is offline
post #7 of 28 Old 11-03-2008, 11:21 AM
TJamz
What did Jerrys post say about Diff fluids?
TJamz is offline
post #8 of 28 Old 11-03-2008, 11:25 AM
Marauder_Pilot
Marauder_Pilot's Avatar
I generally change every season. I'm going to do everything this month, since I need to 'winterize' the Jeep as well.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #9 of 28 Old 11-03-2008, 11:48 AM
suntzur
Using Amsoil, I've been on a once per year schedule for the past 18 years or so. I run the fresh Amsoil in my vehicles, pull it out and put it into my father-in-law's Toyota and he runs it until the next season.
Amsoil's 0-30 Signature series is a 35k mile oil and even though they recommend changing it annually, I'm going to push it to the 35k just to see what it does. I'll change my plan if the oil starts to look nasty. I ran my Ford Focus HARD with 0W20 for over a year and it literally looked like I had stuck my dipstick into a fresh quart of oil. That engine was obviously well taken care of prior to then, but it was encouraging to see it so clean.
suntzur is offline
post #10 of 28 Old 11-03-2008, 12:40 PM Thread Starter
TJShadow
I've heard some people say that AMSOIL is just snake oil by a different name because it doesnt have the different standards that it meets listed on the label. I like the idea of only changing my oil once a year though. I'm going to have to look into that more.
What about the transmission? How often does everyone change their transmission fluid?
TJShadow is offline
post #11 of 28 Old 11-03-2008, 01:43 PM
GREASEMONKEY
5k or 6mo on conventional oil is fine. 3mo is somthing designed to boost sales at jiffy lube! Oil actually does start to seperate after about 13mo used or not!
UM... pick up a quart! It's there! The olderqts didn't have the info listed on the bottle, but was readily available from a dealer, or on the web site!
AND NO I'M NOT A DEALER, I'm a user!
post #12 of 28 Old 11-03-2008, 02:05 PM Thread Starter
TJShadow
OK, so with synthetic motor oil I should be fine with an annual change - unless I'm driving a lot. What about the other fluids? Does your differential really need to be changed every 12k?
TJShadow is offline
post #13 of 28 Old 11-03-2008, 02:08 PM
digitalcox
digitalcox's Avatar
I usually stick with what the manual recommends on fluid change intervals. I've been using Valvoline for my engine oil, diffs and t-case while using the mopar fluid for the transmission. Jeep is running good and I don't have any issues.
digitalcox is offline
post #14 of 28 Old 11-03-2008, 03:05 PM
Ole Yeller
Ole Yeller's Avatar
2010 JK Wrangler
On the 05-06 6 speeds, the owners manual says use Mopar part no. xxxxxxxxx or equivilent. No specs on the oil at all. What weight is it? The dealer couldn't even tell me.
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
Ole Yeller is offline
post #15 of 28 Old 11-03-2008, 04:29 PM
NH2112
I would include an engine oil analysis as part of any change to long (greater than 5K-7.5K) engine oil drain intervals. You'll only need to do it once for the initial drain, I'd personally drain a sample once a year afterward and have it analyzed but it's not 100% necessary.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
Change fluids or not? stwolf TJ Wrangler Technical Forum 14 05-27-2009 07:54 PM
Change the dif fluids Shane64 TJ Wrangler Technical Forum 12 04-16-2007 11:20 AM
How do I change the fluids eprovenzano TJ Wrangler Technical Forum 1 01-20-2006 08:41 AM
Should I change fluids or not? Bren Gun TJ Wrangler Technical Forum 3 08-15-2005 02:21 PM
How often do you change your fluids????? 4-low YJ Wrangler Technical Forum 4 11-18-2001 08:52 AM
