How often do Johnny Joints need grease - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How often do Johnny Joints need grease
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFHELLA FF75 12V 55W H7 Fog Lamps - SPECIAL OVERSTOCK SALE F
Unread 01-19-2013, 06:49 PM   #1
Hwkscr
like the topic says... I can easily slip the grease gun on the upper grease zerk but ill have to drop the arms to reach the lower, how often do you add grease to your johnny joints? Any tricks to greasing the lowers w/o dropping them? I'm looking into 90 degree zerks, but again gotta drop em.
4" Pro-Comp springs / Bilstein 5100's / Rokmen Adj LCA's / Currie Currectlynk Steering / Currie Adj FTB / JKS Adj RTB / Warn F&R bumpers w/ tire carrier / KC daylights w/ windshield mounts / 285/75/16 Duratracs / Moab wheels / Cobra CB / Sirius XM / Skid-Row Engine Skid / Warn VR8000 / 05 Unlimited Rubicon Sahara 557/1000.
Hwkscr is offline   Reply With Quote Quick reply to this message
Unread 01-19-2013, 07:32 PM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I attempt to grease them once a year, but they don't seem to need any...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 01-19-2013, 08:16 PM   #3
Hwkscr
Knuckelhead, are you a daily driver? your rig see any mud?
Unread 01-19-2013, 08:25 PM   #4
55willystruck
Mine is, and does. I was greasing them far more than they needed at every oil change. With the new build, haven't greased them since install, and won't for a while yet...
Best of Luck,
Mike
55willystruck is offline   Reply With Quote Quick reply to this message
Unread 01-19-2013, 08:28 PM   #5
Hwkscr
Thanks 55!
Unread 01-19-2013, 08:30 PM   #6
Knuckelhead
AFSOC Retired
Yes.
You have to take into account that I'm retired, but the JJ's were installed long before I retired (8 years).
Mud?
Nope, not if I can help it...
Unread 01-19-2013, 08:34 PM   #7
55willystruck
No problem! If it helps at all, I had well over 65K on the first set before the new build. Tore them down, greased them, and those are now on another rig still going strong.
I am a firm believer in the JJ's being the best dual-purpose joint out there. Very little maintenance, and they last forever. -ok maybe not forever, but almost.
I put the 2.5" 1.25" shank JJs on the new 3/4 link build. Very happy with them as well.
Word of caution-do NOT over-grease them!!! You can kill them quick doing that-this is a case where more does NOT = better. A little goes a LONG way.
Best of Luck,
Mike
