How much "sway" does your jeep have at highway speeds? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How much "sway" does your jeep have at highway speeds?
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread Yesterday, 08:31 AM   #1
JDG98TJ
I've always attributed it to just being a lifted jeep. But I wanna know how much sway other jeeps have, my tj is a 98, 4.5" RE SA lift with RE ADJ Track bars. 35's BFG AT's and I can barely keep it between the lines.
So here's what I've done so far. New ball joints, wheel bearings, u joints, anti rock, tightened all bolts, and adj. the front sway bar, balanced tires, and had it aligned. I'm stumped
JDG98TJ is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:47 AM   #2
Imped
Imped's Avatar
Take a head on picture of your Jeep--make sure the pitman arm, track bar and both knuckles are in the picture.
How do you control arm bushings/joints look?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:13 AM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
And make sure we can see how much 'drop' the Pitman arm has which requires a pic of it from the side.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 09:41 AM   #4
biffgnar
biffgnar's Avatar
When you had it aligned, what was the caster? What pressure do you run in your tires?
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:56 PM   #5
JDG98TJ
Will do, tp around 32-35, and control arm bushings are still good no cracks or rips.
Unread Yesterday, 01:57 PM   #6
JDG98TJ
Caster was in the red but not by much. Just barely.
Unread Yesterday, 02:16 PM   #7
biffgnar
biffgnar's Avatar
Red based on what standards? The stock numbers in their computer or range adjusted for bigger tires? And what exactly was the number? I'd say take your tire pressure down to 24 are and get your caster out to around 6 and I bet you see a material difference in handling.
Unread Yesterday, 02:21 PM   #8
JDG98TJ
Prob for a stock jeep standards and I'll look for the paper for the degrees, How do you ADJ camber on a jeep? Also will try the 24 psi
Unread Yesterday, 02:24 PM   #9
biffgnar
biffgnar's Avatar
Camber is generally not adjustable. Well, there are offset ball joints, but they are more of a replacement part rather than an adjustment. Do you have a camber issue also?
What you describe for handling sounds like a caster problem. For minor adjustments cam bolts can be used on the front lowers, but with an RE 4.5" (that's potentially giving you even more than that with their springs) you need to use adjustable control arms to put caster back in.
Unread Yesterday, 03:21 PM   #10
JDG98TJ
TP adjusted to 25 and here's the pics. I can't find my papers for the alignment. Should I get another one to get the specs or is there some other things I can try first?
Unread Yesterday, 03:23 PM   #11
Imped
Imped's Avatar
Drop pitman arm is generally an automatic sign of ignorance. Post a picture of the frame side track bar mount.
OlllllllO
Float Test Build
IndyORV
Unread Yesterday, 03:24 PM   #12
JDG98TJ
A little better pic
Unread Yesterday, 03:28 PM   #13
JDG98TJ
What do you mean by an automatic sign a ignorance?
Unread Yesterday, 03:29 PM   #14
Imped
Imped's Avatar
I can't see the track bar mount but judging by the angle, it's not dropped.
EDIT: You just posted the picture. The drop pitman arm is your problem.
Have someone turn the steering wheel while you watch below--start nearest to the wheel (steering shaft) and work your way down to the steering box (input = output?) and so on to every joint, including the track bar. If you have play then that will translate to difficulties for you. Knowing your actual caster would be beneficial to us as well.
OlllllllO
Float Test Build
IndyORV
Unread Yesterday, 03:30 PM   #15
JDG98TJ
BTW that's LPS3 on the heim, A/C Grade Corrosion inhibitor
