How much lift with stock track bars and bumpstops - JeepForum.com
post #1 of 8 Old 07-23-2010, 09:38 PM Thread Starter
bones5150
I have looked through the faq and searched but can't find an exact answer for my question, its a simple one...........how much suspension lift can I do with stock trackbars and bumpstops and still be able to align it?
Any help is greatly appreciated!
if i wanted a HUMMER, i'd ask your wife!
bones5150 is offline
post #2 of 8 Old 07-24-2010, 06:21 AM
nikeo02
Well, stock bump stops do not affect your alignment at all. It simply limited the amount of flex you can have by "bottoming out" when you reach a certain point.
As for the track bars, i wouldn't go over 4 inches without going adjustable. And even at 4 inches, you should go adjustable in the front.
2003 Yellow TJ
nikeo02 is offline
post #3 of 8 Old 07-24-2010, 06:29 AM
speepdaedeesi
the questions you need to ask/search for is how high can you go before you need a sye/transfer case lift/etc, and how big of tires can you have with what gearing/axles.
thoooooose are the questions.
trackbar extensions, adjustable trackbars, and bump stops are all easy fixes
89 yj stock- sold
92 yj stock- sold
97 tj 2"bb,31" tires- sold
95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold
95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold
current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T
speepdaedeesi is offline
post #4 of 8 Old 07-24-2010, 06:49 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Most people don't bother with adjustable track bars or brackets with 2" of lift or less.The axle should only shift about 1/2" or so.Add a BL if you need more room with out effecting the driveline or axles.Bumpstops need to be lengthened with any lift if you go offroad.
TheBoogieman is offline
post #5 of 8 Old 07-24-2010, 06:50 AM
TheBoogieman
Disturbed
Originally Posted by speepdaedeesi View Post
the questions you need to ask/search for is how high can you go before you need a sye/transfer case drop/etc, and how big of tires can you have with what gearing/axles.
Fixed that for you.
post #6 of 8 Old 07-24-2010, 06:51 AM
catITguy
By 4" you will need adjustable. 2" you wont. Between those is probably a matter of preference, but could likely be solved with a relocation bracket.
2000 Wrangler Sport, 4.0L auto
OME 2.5" Suspension Lift
1.25" JKS BL and 1" MML
33x12.5 GoodYear Wrangler Duratracs
catITguy is offline
post #7 of 8 Old 07-24-2010, 06:58 AM
robncar
robncar's Avatar
I'll chime in with a 2" BB and a 1" BL.
But, you will need new shocks.
P.S. You might want to change your signature, family forum.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #8 of 8 Old 07-25-2010, 06:52 PM Thread Starter
bones5150
Thanx for the help guys
max , maximum , lift , track bar , trac bar , bumpstop , tj , wrangler
removing track/sway bars on stock Roadyy YJ Wrangler Technical Forum 6 04-28-2010 06:37 AM
Are these stock track bars? slush TJ Wrangler Technical Forum 6 03-25-2009 06:22 AM
lift kit question about track bars gary67 TJ Wrangler Technical Forum 3 12-28-2008 10:05 PM
BDS lift w/out Track Bars gumby885 YJ Wrangler Technical Forum 5 09-14-2008 09:08 PM
Rubicon springs with 1.5" spacers for lift. Problems with stock arms/track bars? DINOCAVE TJ Wrangler Technical Forum 9 02-14-2006 03:45 PM
