How much of a lift do i need? - JeepForum.com
post #1 of 25 Old 01-07-2014, 08:42 PM Thread Starter
Kiliandowning
I have a 2000 tj and everything is completely stock on it. A good friend of mine said he would sell me his Super swamper radail tsl's for 100 dollars...they are 35s. i didn't want to put 35s on it but for a hundred bucks, why the hell not. Would an Inch and a quarter be enough lift? i have never put a lift on anything before so im not very knowledgeable when it comes to this.
thanks
Jeeps, Banjos and Whisky
Kiliandowning is offline
post #2 of 25 Old 01-07-2014, 08:44 PM
stockerokie
There Is a thread " what do I need to run 35s"
It's a Long list. Welcome to the forum.
stockerokie is offline
post #3 of 25 Old 01-07-2014, 09:23 PM
3X4X4
By the time you do all of the things that REALLY ARE NEEDED to lift a Jeep to accommodate and utilize functionally and safely 35 inch tires, the $100 will sound like chump change.
J
3X4X4 is offline
post #4 of 25 Old 01-08-2014, 12:52 AM
tyvanwie
Don't do it.
tyvanwie is offline
post #5 of 25 Old 01-08-2014, 04:05 AM
rda616
5" is the recommended amount of lift for 35" tires. That's 4" suspension and 1" body. There are other ways like metalcloak fenders, but even than I would still want a couple inches of lift.
As already stated there is more to running 35" tires safely than just a lift.
rda616 is offline
post #6 of 25 Old 01-08-2014, 04:27 AM Thread Starter
Kiliandowning
Ok. So should I not even bother with going with something as big as 35s? I'm going to lift it anyway, would a smaller tire be less of a pain in the ***? I have driven hatch backs my whole life so thus is all kinda new to me.
post #7 of 25 Old 01-08-2014, 04:34 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Go with 33's at the most.I paid $1200 for my tires alone.
TheBoogieman is offline
post #8 of 25 Old 01-08-2014, 05:06 AM
sc00bz
If you don't want to pay out a pretty good sum of money, stick with 33s. You'll be looking at around $1000-1500 between suspension and steering if you don't go top of the line parts wise or buy used. That can be offset with cloaks or highlined fenders but will still cost $1k+ if you don't fab them up. If you have a dana 35 rear, you'll be looking at another $500-2500 for a beefier rear axle depending on if you build it or buy it. Another $500-1000 on gears (not completely necessary but it will make life easier daily driving and gas milage wise). Then you still have to upgrade brakes, etc.
97 TJ with some stuff.
sc00bz is offline
post #9 of 25 Old 01-08-2014, 07:30 AM
Ross
Driveline angles, which axles you have, steering and brake up grades all come into play when you talk about running 35s. Any of those could cost more than the lift itself. Any time you go above 3" susp and maybe even a 3" susp lift you can run into drive line angle issues. Like stated above you can get around some suspension lift needs by dealing with fenders but you may still have issue with the axles, brakes that should be looked into.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #10 of 25 Old 01-08-2014, 10:11 AM Thread Starter
Kiliandowning
Cool. Thanks for all the help and info everyone
post #11 of 25 Old 01-08-2014, 10:40 AM
stump1
meh.. u could lift it and have it on yer 35's for under $800 if you wanted to all said and done if you do the work yourself.
i did that to a rig and ran it like that for years not touching a thing.
not the best way to go, but you can do it
MY RIG: http://i78.photobucket.com/albums/j87/ramburger/a0fcb769-5e55-4a62-8426-cb7cce41c0c2_zpsccea3c78.jpg
stump1 is offline
post #12 of 25 Old 01-08-2014, 12:38 PM Thread Starter
Kiliandowning
I do plan on doing it all myself.
post #13 of 25 Old 01-08-2014, 01:30 PM
Ross
What all did you end up doing?
Ross is online now
post #14 of 25 Old 01-08-2014, 01:48 PM
rda616
You have a 2.5 so you definitely have a Dana 35 rear. Do you have a 5 speed (ax5), or an auto (30rh). Either way you want to regear to or you will have very lack luster power. The lowest gear ratio you can get for you axles is 4.88 and you will want every bit of that even for 33's and a ax5. The 30rh can get by with with 4.56 gears.
rda616 is offline
post #15 of 25 Old 01-08-2014, 01:53 PM
stump1
just a 4" suspension and some 35's
funny thing is i had a blast with it in the woods too on the dana 35..
stump1 is offline
lift advice
