How much lift do I have? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How much lift do I have?
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 07-25-2015, 01:40 AM   #1
CountryDriven
Just bought a jeep today! 50k miles 1 owner sahara, been looking for awhile and while I'm not big into the chrome that can be changed! Here are some pics of the jeep... the transfer case is dropped so that leads me to believe its 3 inches or so.. has 30" tires. I am also wanting to lift the rear a bit more to level it out since its sagging a bit, but before that I'd really like to know how much lift I have prior...Thanks
CountryDriven is online now   Reply With Quote Quick reply to this message
Unread 07-25-2015, 02:06 AM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Can you post pictures of the suspension springs and body mounts?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 08:06 AM   #3
TheBoogieman
Pure Evil Jeep freak!
TheBoogieman's Avatar
Front springs 12"/rear 8". Anything over is a lift or measure the width of any spacers on top of the springs (BB).
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 02:17 PM   #4
CountryDriven
I don't think it's got a body lift but could be wrong, I will post pictures when I get home today!
Unread 07-25-2015, 10:40 PM   #5
CountryDriven
Here's the suspension:
Front:
Rear:
Unread 07-25-2015, 10:45 PM   #6
CountryDriven
The speedometer is 10mph over so I think they had 32s or 33s on it at some point.
Unread 07-25-2015, 10:52 PM   #7
CountryDriven
I dont think those are stock rear control arms...from looking at pictures on google
Unread 07-25-2015, 10:56 PM   #8
Knuckelhead
AFSOC Retired
Front:
Rear:
[IMG]
The front axle side track bar mount looks to be re-drilled, look here for information on that: http://www.jeepforum.com/forum/f9/br...racket-905624/
Those control arms look like early TeraFlex arms and are only good for tearing the control arm mounts off of the axle and frame... HTH
Unread 07-25-2015, 11:02 PM   #9
CountryDriven
I was looking at quadratec and found this 3" suspension lift...pretty sure thats what I've got!: http://www.quadratec.com/products/16110_012.htm I guess the PO just also put extended rear arms on the jeep...Does this mean I could add a 1 inch spacer to the rear to match the 1" spacer on the front safely? I want to say within the proper geometry of my suspension...Thanks!
Unread 07-25-2015, 11:18 PM   #10
Knuckelhead
AFSOC Retired
I don't see a 1" spacer on the front?
What I posted is saying that you need to replace the aftermarket control arms with something that actually works...
Unread 07-25-2015, 11:52 PM   #11
CountryDriven
All you posted was that you wanted pics, whats wrong with my aftermarket control arms?
Unread 07-25-2015, 11:54 PM   #12
CountryDriven
[QUOTE=Knuckelhead;31167513]I don't see a 1" spacer on the front?
Ok so I guess those are just dampeners like on my old ranger's dana 35 coil springs...
Unread 07-26-2015, 12:03 AM   #13
Knuckelhead
AFSOC Retired
The ones you have are garbage.
Yep...
Unread 07-26-2015, 12:25 AM   #14
CountryDriven
Yep...
Do you know what type I have, I'll research my particular one's faults. Will I be OK leveling the back with the front, seems to be abit lower...
Unread 07-26-2015, 12:28 AM   #15
CountryDriven
They're fixed like these I think...http://www.ebay.com/itm/Jeep-TJ-Wran...4f8fbe&vxp=mtr
Gunna go check it out.
