How much does an Unlimited hard top weigh? - JeepForum.com
post #1 of 9 Old 05-19-2005, 09:47 AM Thread Starter
Mr. Tarmac
Ball park is fine. Just curious how much the unlimited hard top (or standard hard top) weighs.
Mr. Tarmac is offline
post #2 of 9 Old 05-19-2005, 10:07 AM
mdot
a bunch.
It's a minimum two man lift if you want to carry it some where.
That being said, I think it's under 200#. I used four comalongs to lift it off my jeep and then lowered it to the ground. I was able to slide it around on cardboard (the cardboard was sliding around on teh concrete actually). And the lifted one end, by myself, to a vertical position for storage. ( I used two comalongs to raise it in the vertical position (front down) against the wall and almost out of the way. teh two comalongs had zero problem lifting the weight, what ever it actually is)
I know it's not a #, but I hoep this helped.
mdot is offline
post #3 of 9 Old 05-19-2005, 10:11 AM
nwquadriders
It's not that heavy....just akward. A friend and I lifted mine off by hand and carried it 30+ feet to where I have it stored. It's an easy lift...maybe 150 pounds...It was a lot lighter than I expected it to be.
'04 Solar Yellow Wrangler Unlimited: 3.5" RE Superflex w/ RE Monotube shocks, 33x10.5 BFG MT's, Warn XD9000i winch, Jeeperman Trail Skids & Rear Bumper/Tire Carrier with 1/4 Panel Guards. Skid row engine skid.
nwquadriders is offline
post #4 of 9 Old 05-19-2005, 12:19 PM
snowjoker
I agree with the post above, a friend and I took it off and carried it a ways to the storage rack I built. I would also guess around 150lbs.
Much lighter than it looks!
05 Unlimited, Auto, Khaki, Dual Tops, RE 3.5" Super Flex lift, 33/12.50/15 Mickey Thompson Baja MTZ, 15x8 ProComp Extreme Alloy 1069 Wheels
My Ride:
My trunk Box:
snowjoker is offline
post #5 of 9 Old 05-19-2005, 12:42 PM
TXST8tj
TXST8tj's Avatar
150 pounds for a standard HT...probably 175-200 for an unlimited HT...of course due to the extra side glass.
Patrick
TXST8tj is offline
post #6 of 9 Old 05-19-2005, 01:34 PM
TJ Unlimited
Yeah I agree, about 175 on the Unlimited top. Took me and friend to lift it off. If you were gonna hang it from a hoist I would think 200lbs would cover it. Of course if I were gonna stand under it I make sure it held 250.
TJ Unlimited is offline
post #7 of 9 Old 05-19-2005, 05:24 PM
unlimited05
I've had my unlimited less than a week and haven't taken the top off yet. I'm hoping to get something rigged in my garage to hoist the top off. My concern is that my house is a split level and I don't have a lot of extra clearance in the garage. My quesiton is, how much do you have to lift the top to pull out from underneath it? A couple inches? a foot?
unlimited05 is offline
post #8 of 9 Old 05-19-2005, 05:48 PM
ninjajeep
ninjajeep's Avatar
A couple of inches is fine, just be careful when pulling out and backing under it.
'01 TJ 60th Anniv. Ed.
"6 cylinders of gut wrenching torque"
ninjajeep is offline
post #9 of 9 Old 05-19-2005, 06:28 PM
mebob
mebob's Avatar
I assuming it 's not to much more than the standard TJ top. Most of weight seems to be the back window and even more awkward it tends to open up when you start to list it off.
I took mine off by my self, last summer. The jeep was knew I nothing was going to stop me from going topless. My girl friend tried to help but she couldn't reach up high enough. Just some advice DON'T do THAT! I came pretty close to dropping it, there is very little to hang onto when you just have it hoisted on your back. I also managed to get it back on later that day. Moral of the story either get help or built a hoist it's more awkward than anything. The top survived with a few minor scratches but who know what I did to my back I'd only try it again if I had a loading dock or something to back up to.
mebob is offline
4 door unlimited- how much does rear top weigh N2rock JK Wrangler Technical Forum 7 08-04-2007 02:57 PM
How much does the hard top weigh? sgt jeep JK Wrangler Technical Forum 14 05-23-2007 12:45 AM
how much does a hard top weigh ?? magnum629 TJ Wrangler Technical Forum 8 02-10-2006 07:05 PM
How much does a hard top weigh? drew622 TJ Wrangler Technical Forum 7 10-14-2004 06:07 PM
how much does a hard top weigh? renegade91 33" YJ Wrangler Technical Forum 2 07-13-2003 07:37 PM
