Quantcast How to mount CO2 tank? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to mount CO2 tank?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 10-17-2004, 09:06 PM   #1
uscdad
I bought a CO2 system off e-bay. I'd like to be able to mount it so I can remove it when I'm not wheeling and put it back in when I need it. The same seller can get the roll bar clamps that are made to use with the tank bracket.
Is anyone using these clamps?
Anyone have another way to mount it?
Pictures?
White 03 TJ 6cyl auto hardtop
Teraflex 4" lift 4.56 gears
D30 w/Detroit Tru-trac
D44 w/Detroit Locker
33" Goodyear MTR's on 15x8 black steelies
Can't break it until it's paid for!
uscdad is offline   Reply With Quote
Old 10-18-2004, 10:07 AM   #2
BigWaylon
tubework is cool...
BigWaylon's Avatar
I bought mine from him as well...
opted for a black 15# tank (I think it's $10-$20 more)...which uses the same bracket, and is 30" tall vs 23" tall, and the same diameter...
I also got the roll bar clamps...
the 15# might not fit with a hard top, even if you rotate it to inside the roll bar...but the 10# probably will...
I mounted mine on the driver's rear bar...and rotated it to where it didn't stick out the side...the "handle" also serves to protect the regulator, and I picked up a small stuff sack at the local outdoor shop to cover the regulator...
a few pics:
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Old 10-18-2004, 11:23 AM   #3
Shawno
Heres mine:
Big Waylon,
Wouldn't you be concerned of your placement in the event of a rollover?
2001 TJ Sport
Teraflex 3T/MORE 1" BL/33's on Rockrawlers/F:BD At'sR:Tera's/Tera QD's/K&N/AtoZ Rockers+ Bumper/PoisonSpyder Roll cage/ Bestop Tire Carrier/Warn Skids / Olympic rear Bumper/Cb&KC's/OBA/MML in garage ;-) +Bushwackers
[URL=http://img57.photobucket.com/albums/v175/shawno13/DSCN0558.jpg]Pic 1[/URL][URL=http://img.photobucket.com/albums/v175/shawno13/OFR_04/OFR.jpg]pic 2 [/URL]
[SIZE=3][URL=www.newenglandjeepz.com][COLOR=blue][COLOR=red]New[/COLOR][COLOR=white]England[/COLOR]Jeepz[/COLOR] [/URL][/SIZE]
Shawno is offline   Reply With Quote
Old 10-18-2004, 11:28 AM   #4
DiegoYJ
Junior Member
Originally Posted by Shawno
Big Waylon,
That's what I was thinking too. Also, a branch could do some damage to that regulator, sack or no sack.
DiegoYJ is offline   Reply With Quote
Old 10-18-2004, 01:43 PM   #5
BigWaylon
tubework is cool...
BigWaylon's Avatar
I probably should be...
the sack is just for protection from the elements...the tank has a protective ring/handle around the regulator that has fended off branches...
Greg
Old 10-18-2004, 02:20 PM   #6
AudioGuru
Heres mine:
Big Waylon,
Questions:
1) Is that gauge on your tank before or after the regulator?
2) Do you use it to monitor tire pressure or tank pressure?
3) How do you determine that your tank needs refilling?
[URL=http://www.villagephotos.com/pubbrowse.asp?selected=826692][B]Electric Hardtop Hoist[/B][/URL]
[URL=http://www.clifford.com/matrix/responder/default.asp][B]Clifford Matrix[/B][/URL]
[COLOR=White]Don't lie. God said so.[/COLOR]
AudioGuru is offline   Reply With Quote
Old 10-18-2004, 02:51 PM   #7
Shawno
Originally Posted by AudioGuru
Questions:
Gauge is after the regulator. It is a $10 Husky gauge from Home Depot. It regulates from 0-160 and allows me to use air tools. The regulater before it brings the PSI down to 150.
Outgoing tank pressure mostly for air tools if necessary.
When it get's real light. CO2 pretty much runs at a constant pressure until it's completely empty. Only real way to tell is to actually weigh it or simply lift it up and make an educated guess on what's left.
2001 TJ Sport
Old 10-18-2004, 04:40 PM   #8
BigWaylon
tubework is cool...
BigWaylon's Avatar
yep...that's about the only way...
it runs at full pressure right til it cuts off...
it's got the weight stamped into the side, so you can just weigh it...it really is as simple as weighing it empty, and after you fill a 10# tank, it ought to weigh 10 pounds heavier...
they make portable scales for you to hang the tank from, but I just fill mine up whenever I get around to it...it "should" be able to do 60 tires per fillup...(33's from 10 to 20 lbs...)
here's a pic from Stu's site that shows the weight:
you're mostly concerned with the TW (tare weight) of 14.5 lbs...what it should weigh empty...mine is actually 18.4 lbs...
Greg
Old 10-18-2004, 07:42 PM   #9
AudioGuru
Thanks for the details. I picked up a 10lb tank today, and they threw in a beverage style regulator assembly. It has two gauges, one for overall tank pressure(0-3000psi), the other for the adjustable regulator(0-160psi). I may end up getting something different, but I'll see how this setup works out first.
Old 10-18-2004, 07:45 PM   #10
BigWaylon
tubework is cool...
BigWaylon's Avatar
just an FYI...the overall tank pressure guage isn't gonna do much good...the tank will stay at max pressure right until it goes empty, as it's stored as a liquid...
the adjustable regulator will be nice, as you can fill tires at 160 (mine is a fixed 150), and then use lower pressure for air tools if needed...
just make sure the regulator assembly is capable of running CO2 at long intervals (i.e. minutes in a row, instead of short burst) without freezing up...
Greg
Old 10-18-2004, 08:59 PM   #11
TXST8tj
does anyone have the link on ebay where ya'll found these.....seem like they would be just as good as the brand name stuff
Patrick
Build Thread
Goodyear-Corbeau-Hella-DDM Tuning-Alpine-Kicker-JL Audio-Tuffy-KC-Bestop-Firestick-Cobra-Skinny Pedal-Rough Country
TXST8tj is online now   Reply With Quote
Old 10-18-2004, 09:02 PM   #12
TXST8tj
nevermind...i didn't see the link up top in the first post
Patrick
Build Thread
Old 10-19-2004, 08:13 AM   #13
AudioGuru
Overall tank pressure will be nice to have so I can monitor it on hotter days, and try to avoid burst disks.
Greg
We'll find out this weekend...
Old 10-19-2004, 08:35 AM   #14
ncb76
You may want to check out this link. It's the same setup, just a few dollars cheaper.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2494918713&catego ry=43986
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline   Reply With Quote
Old 10-19-2004, 09:21 PM   #15
BigWaylon
tubework is cool...
BigWaylon's Avatar
based on Stu's site (and he did a good amount of research)...as long as you don't overfill the tank to begin with, it's not gonna be an issue...
but, it's obviously not gonna hurt anything by being there...
here's the blub from Stu's site:
A 10# CO2 tank will hold 10# of CO2 when it is properly filled. I stress the word properly because an overfilled CO2 tank, when subjected to summer time temperatures, will quickly build up enough pressure to blow out the 3000 PSI burst disc. When my burst disc blew, I contacted the company who had built my tank (for a replacement) and spoke with one of their top employees. By then, I had heard all manners of horror stories about CO2 tanks blowing up in the Phoenix summers, etc. He assured me that a properly (there is that word again) filled CO2 tank can be half buried in the Mojave desert, all summer long, without any chance of it venting. It is not until the tank is overfilled AND ambient temperature is high that the recipe for a blowout is cooked up. I found some related CO2 tank filling info on the Internet but I will admit it was too technical for me to fully grasp. It went into detail as to how the pressure spikes, based on the percent of overfill and the temperature (among other things discussed). I was able to glean enough from it that I felt comfortable with what the gas tech guy told me on the phone.
let us know how it works out!!
Greg
Glock Forum
