How the Metalcloak Duroflex bushing stacks up - Page 66 - JeepForum.com
 1Likes
post #976 of 1042 Old 08-14-2014, 12:20 AM
26679cj5
Originally Posted by 05LJTampa View Post
Still debating ifi should go double adj or not. I hope to set and leave it.
I think its worth it. I have some single adjustables from another company, but every time I have to fool with the arms, I wish they were double adjustable. Things may change like spring height or a tummy tuck which will require adjusting the arms again.
26679cj5 is offline
post #977 of 1042 Old 08-14-2014, 10:11 PM
REF_NJ
Spring height- as in, wear an tear over time such as sagging? Or upgrading to a different height, thus requiring adjustment of the CA?
One Ball / One Life
Sienna Jeep Owners Member no.68
REF_NJ is offline
post #978 of 1042 Old 08-14-2014, 11:26 PM
26679cj5
Both. Your springs will likely break in after a little while, which may require a small adjustment to the pinion angle, or you might change springs out for a different brand or lift height.
26679cj5 is offline
post #979 of 1042 Old 08-15-2014, 04:22 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Originally Posted by matsonian View Post
Well, here it is... true to my word (almost)...
http://www.youtube.com/watch?v=sMPhoeY0emg
I agree, I hope you didn't actually swallow your hat.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #980 of 1042 Old 05-02-2015, 08:49 AM
UncleWilson
UncleWilson's Avatar
Does anyone know the correct duroflex part for replacing the Currie arm JJ lowers? Is it the 2 5/8" OD x 2 5/16" L or 2 5/8" OD x 2 5/8" L?
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #981 of 1042 Old 05-02-2015, 09:11 AM
Jonny Jeep
Jonny Jeep's Avatar
This one...
http://www.metalcloak.com/2-5-8-D-x2...ade-p/7350.htm
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
post #982 of 1042 Old 05-02-2015, 06:57 PM
26679cj5
Do you guys know if the MC conversion kits work on Rough Country joints?
26679cj5 is offline
post #983 of 1042 Old 05-02-2015, 07:33 PM
willis36
willis36's Avatar
Pretty sure they wont due to the spanner nut on the one side.
willis36 is offline
post #984 of 1042 Old 08-16-2015, 11:51 PM
tcmault
I have been leaning towards JJ arms for years. Now after reading this thread, it looks like MC arms are my next big purchase.
2006 AEV Unlimited Rubicon. Silver. 6-speed. 255/85R16. OME ZJ/LJ. Nth TT. Alloy Shafts.
tcmault is offline
post #985 of 1042 Old 08-17-2015, 09:40 PM
tcmault
I'm still only on page 37 of this thread, so it may be mentioned in the next 30 pages, but I'd like to see a package deal from Metalcloak for their standard lower arms and the double adjustable uppers. Once I have the length on the bottom set, I usually only mess with pinion angle by adjusting the uppers. Obviously, it can be done by purchasing the pairs separately. Once you decide to spend the money, what's a couple more dollars.
tcmault is offline
post #986 of 1042 Old 08-17-2015, 10:14 PM
Ljcrawler05
Why not just call them?? They will work something out for you I'm sure.
Ljcrawler05 is offline
post #987 of 1042 Old 08-18-2015, 12:27 PM
sardog12
sardog12's Avatar
You really can't go wrong with either but I consider my MC arms to be likely the best upgrade on my Jeep so far.
GEAUX TIGERS
sardog12 is offline
post #988 of 1042 Old 08-18-2015, 09:50 PM
MarioM0one
After having read the thread over a long time, (thanks Imped) I just installed 4 lowers and 2 front uppers, as I already had installed 2 upper, double adjustable JJ upper rears when I did the TT. I did the fronts first and a week later the lower backs. Each time the ride improved noticeably. Haven't taken wheeling yet, but I am expecting to be awed.
MarioM0one is offline
post #989 of 1042 Old 08-20-2015, 11:33 PM
ultimo
Just a quick query....do MC bushings work on the Dana 30 front passenger upper axle side?
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline
post #990 of 1042 Old 08-21-2015, 05:31 AM
elclipo
They still don't have an axle side bushing/kit. Still using the stock clevite bushing on the axle and the "fork" front section on the arm.
Semper Fi
elclipo is offline
control arms , duroflex
