How the Metalcloak Duroflex bushing stacks up - Page 64 - JeepForum.com
 1Likes
post #946 of 1042 Old 07-23-2014, 01:52 PM
bbradUSMC
Originally Posted by Jwolfer View Post
Double adjustable would be super convenient and they just looks better.
Convenient for what exactly? How much are you really going to be changing the length of your control arms?
I wish the aluminum arms were available when I ordered mine. I would have paid an extra $200 in a heartbeat.
Honestly I want as much strength in a control arm as possible. Think about landing on rocks. Are the aluminums just as strong?
Only thing I could see would be loss of weight but is the weight difference that much of a difference? Also wouldn't loss of weight bellow your frame make your rig more top heavy increasing your chances of roll over?
Just food for thought.
Sent from AutoGuide.com Free App
bbradUSMC is offline
post #947 of 1042 Old 07-23-2014, 02:40 PM
Ljcrawler05
From what I've read they're not actually that much lighter if at all... aluminum threads strip easier... and the only plus is that they can take a "harder" hit but will likely break before they bend. I'm not gonna try and explain the aluminum vs. Steel argument because it's been done before many times... and very well by mr. blaine. For the most part we will never be able to abuse either to the point of failure. It's more about convenience than strength... and the other day until I figured out the ratchet strap method I was wishing for double adjustables
Ljcrawler05 is offline
post #948 of 1042 Old 07-23-2014, 03:28 PM
Jwolfer
I have already adjusted 6 out of 8 arms a number of times which is kind of a pain. It doesn't take too long but it would be nice to not have to disconnect everything. I have them set pretty good now but I might adjust them to fine tune some things.
Jwolfer is offline
post #949 of 1042 Old 07-23-2014, 03:41 PM
clg82
how "much" or how "often"? with a high clearance tummy tuck like yours you're going to be adjusting them "much" steeper than stock, and if they are adjustable they are much easier to adjust when setting everything correctly.......
clg82 is offline
post #950 of 1042 Old 07-23-2014, 04:59 PM Thread Starter
Imped
Imped's Avatar
Aside from being ever so slightly easier to adjust, they make initial installation a breeze--adjust the arm to fit the axle instead of vice versa and slide the bolt through. Once bolted up, fine tune lengths. Go spend a weekend doing a couple full installs and you'll learn to appreciate RH/LH threaded arms.
OlllllllO
IndyORV
Imped is offline
post #951 of 1042 Old 07-23-2014, 06:19 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
I thought I'd add that I towed my trailer some distance on Sunday. The trailer is about 1100#s and it towed great at 70 mph as well as on some dirt roads. Again, the added tightness and improved ride is nice.
I believe that Metalcloak's web site says that the aluminum arms are slightly heavier.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #952 of 1042 Old 07-23-2014, 06:22 PM
bbradUSMC
How often, sorry for the confision. Mine wasn't bad at all. Got the axle centered on bump stops, then squared them, and then set the pinion angle. I just never tightened anything down until then end. One shot was all it took for me.
If you are doing multiple I can definitely see the double adjustable being much better and more time efficient. For the regular joe working on his personal rig I don't see it being worth the added cost. Yes, quicker and easier install, but if you know what you're doing it isn't a big deal. Also, proper tools make the job even easier.
post #953 of 1042 Old 07-24-2014, 09:46 PM
dongalonga
Agreed. The only way it is worth more $$$ is if you are constantly doing installs/changes. For the average Jeeper it is not money well spent.
dongalonga is offline
post #954 of 1042 Old 07-24-2014, 10:00 PM Thread Starter
Imped
Imped's Avatar
And I'm sure others share a different opinion. I don't disagree with you but I can appreciate both points of view since I have plenty of experience with RH/LH arms and those with one end barrel welded.
OlllllllO
IndyORV
Imped is offline
post #955 of 1042 Old 07-24-2014, 11:18 PM
pcoplin
pcoplin's Avatar
Then use 1/4 inch chromoly tube, and internally sleeve it with 7075 solid rod. IT won't go anywhere.
pcoplin is offline
post #956 of 1042 Old 07-25-2014, 07:44 AM
elclipo
I look at it from three different views:
1. ease of installation
2. ease of modification (fine tuning)
3. compatibility with future changes. I can change the arms and keep the joints in the future if/when I go to a four link system, mid-arm, or pretty much any other setup.
elclipo is offline
post #957 of 1042 Old 07-25-2014, 07:59 AM
Tonellin
oh boy...that is really going to bend some minds around here. Definitely gonna add some more fuel to the aluminum/steel debate....
Agreed. Even though I snagged a set of used double adjustable lowers I don't see myself actually utilizing them to their potential - at least not enough that I would appreciate them for the extra upmark in cost (if bought new....)
But if ya got the extra scratch and want to go nuts then double adjustables certainly aren't the worst thing an average joe could spend his money on
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #958 of 1042 Old 07-25-2014, 09:16 AM Thread Starter
Imped
Imped's Avatar
In my case, the solid aluminum arms of the same length are slightly lighter than the 2" x .25" wall DOM arms I built initially. But I clearly didn't switch them out for strength or weight....I did it because I like aluminum, they're unique, and they don't require any touchups.
OlllllllO
IndyORV
Imped is offline
post #959 of 1042 Old 07-25-2014, 11:51 AM
elclipo
Only one set is heavier. Upper rear I believe.
Add that to my list of reasons why I bought them.
elclipo is offline
post #960 of 1042 Old 07-25-2014, 03:29 PM
Jwolfer
Exactly. I think they look nice. They'd look great with my Bilsteins.
Jwolfer is offline
control arms , duroflex
