How the Metalcloak Duroflex bushing stacks up - Page 59 - JeepForum.com
 1Likes
post #871 of 1039 Old 02-27-2014, 01:03 PM
Ljcrawler05
Originally Posted by EricsGreen98Tj View Post
So if I go with MC front uppers what should I replace the bushings in the front axle housing with? The JJ kit? Or does MC make a duroflex bushing for the axle housing that I'm just not seeing on their site?
What about running JJ front uppers with the JJ housing kit and MC front lowers?
Good idea? Bad? Will my Tj burst into flames mixing CA's like that?
Thoughts?
This has been covered in this thread somewhere.. somebody actually used a duroflex bushing for the front upper with either the JJ housing or a homemade bracket.
It has been stated by metal cloak that you are better off running the stock bushing than a JJ on the same control arm. The reasoning was that the JJ does not realign like the duroflex and they would ultimately be fighting each other causing the bushing to wear prematurely.
Ljcrawler05 is offline
post #872 of 1039 Old 02-27-2014, 01:27 PM
EricsGreen98Tj
Yeah I found the post about not running two different ends on the same arm.
But haven't found anything about Currie Uppers and MC lowers.
Thanks though.....kinda long thread.
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #873 of 1039 Old 02-27-2014, 01:33 PM
Ljcrawler05
Actually I believe I read where one guy preferred the stability of Currie ftont lowers and metal cloak for the rest. Just keep searching and I'm sure you'll find your answer sorry I can't give you exact locations I'm in class and on mobile
post #874 of 1039 Old 02-27-2014, 02:52 PM
bbradUSMC
At the moment I am thinking of ordering MC lowers F/R and Currie uppers F/R mainly because I already have Currie rear upper to adjust my pinion angle.
bbradUSMC is offline
post #875 of 1039 Old 02-27-2014, 03:02 PM
bobthetj03
But the MC front uppers are so purdy!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #876 of 1039 Old 02-27-2014, 03:06 PM
bbradUSMC
I know, I know. I have to stop watching their video. Makes me want to buy them right now.
post #877 of 1039 Old 02-27-2014, 03:11 PM
bobthetj03
And yes, those are Currie lowers. Soon to be replaced by MC lowers.
Bob's boring build:
post #878 of 1039 Old 02-27-2014, 03:13 PM
bbradUSMC
How does it ride currently compared to before and stock if you can remember?
post #879 of 1039 Old 02-27-2014, 03:19 PM
bbradUSMC
BTW what are your plans for the stock upper axle bushing?
post #880 of 1039 Old 02-27-2014, 03:20 PM
Ljcrawler05
I know you didn't ask me, but I'm going to run the stock bushing until metal cloak releases their own solution
post #881 of 1039 Old 02-27-2014, 03:22 PM
Tonellin
How many miles on the currie lowers? sorry if you've already stated, just wondering why the switch
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #882 of 1039 Old 02-27-2014, 03:47 PM
bobthetj03
Steering and handling are much more responsive. A little bit of road transfer to the steering wheel, but exceptable for the gains.
Keeping the stock clevites until MC comes up with a solution.
About 25K miles and 3 years old. No sign of wear at all.
Bob's boring build:
post #883 of 1039 Old 02-27-2014, 03:54 PM
bbradUSMC
Been off road yet?
Been waiting for it.
How often did you grease. Ever disassemble to clean them?
post #884 of 1039 Old 02-27-2014, 04:04 PM
bobthetj03
Been off road yet?
Many times! Had to readjust my bumpstops because of the added flex.
Usually when I do an oil change (every 5Kmiles), but I doubt they need it that often. No, I have not taken them apart yet. I will though when I replace the JJ's for Duroflex joints.
Bob's boring build:
post #885 of 1039 Old 02-27-2014, 05:21 PM
Tonellin
cool thanks! good info to know
06 LJ Rubicon
Tonellin is offline
control arms , duroflex
