How the Metalcloak Duroflex bushing stacks up - Page 53 - JeepForum.com
 1Likes
post #781 of 1039 Old 11-13-2013, 02:01 PM
elclipo
Originally Posted by matsonian View Post
As requested... Double Adjustable Aluminum Control Arm Lengths...
Thank you sir.
elclipo is offline
post #782 of 1039 Old 11-13-2013, 02:17 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Originally Posted by Scarfist View Post
Do you have these in stock at the shop? I work in Sac and can pick them up after work.
We are about two weeks out currently on orders.
It's Your Jeep, Only Better. |
For quotes or customer service
Lots and Lots of Videos:
matsonian is offline
post #783 of 1039 Old 11-13-2013, 06:10 PM
04TJay
Would it be possible to get the control arm length's for the single adjustable ones as well?
04TJay is offline
post #784 of 1039 Old 11-13-2013, 06:12 PM
Ljcrawler05
This^^^
Ljcrawler05 is offline
post #785 of 1039 Old 11-13-2013, 06:52 PM
geiman
What are the new arms made from? 7075?
geiman is offline
post #786 of 1039 Old 11-13-2013, 07:11 PM
aparke4
We definitely have some more pressing projects. Sorry. As a matter of record, we are actually not that concerned about using the stock bushing. Yes, it would be nicer to have Duroflex there, but remember, if you have a rigid flex joint at one end and the clevite at the other end, the clevite gets overworked by the rigidness of the flex joint. With the Duroflex Joint, the clevite does not get worked as hard, so is a better compliment to the Duroflex.
Thanks for the quick response!!
aparke4 is offline
post #787 of 1039 Old 11-14-2013, 10:38 AM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Originally Posted by geiman View Post
6061? 7075?
The Metalcloak Double Adjustable Aluminum Control Arms are manufactured out of solid 1 Extruded Aircraft Grade Aluminum (6061) Hex Bar.
post #788 of 1039 Old 11-16-2013, 01:13 PM
04TJay
Bump...
04TJay is offline
post #789 of 1039 Old 11-16-2013, 01:24 PM
aparke4
I think they have been posted elsewhere but IIRC:
16 inches eye to eye collapsed
18 inches extended
that's what mine measured anyways...
This is for the lowers, single adjustable MC duroflex arms.
aparke4 is offline
post #790 of 1039 Old 11-16-2013, 02:12 PM
1993sahara
Am I able to replace the jj in current control arms with these duroflex joints?
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #791 of 1039 Old 11-16-2013, 07:58 PM
aparke4
yep!
http://www.metalcloak.com/Jeep-Suspe...arts-s/235.htm
aparke4 is offline
post #792 of 1039 Old 11-23-2013, 05:53 PM
jeepinhokie
Originally Posted by jeepinhokie
The zinc coating is doing what it was designed to do. Very pleased with the product.
Still doing its job. Only rust is on the painted steel parts of my custom made arms. Quick rattle can job on the arms and mounts and all is back to good.
HOKIES UNITED!
jeepinhokie is offline
post #793 of 1039 Old 11-27-2013, 05:18 PM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
Sorry for the delay on this...
post #794 of 1039 Old 11-27-2013, 09:40 PM
aparke4
Btw the single adjustable on go to 16 inches eye to eye at the shortest length. My arms were ok with my lift but they will not adjust to stock length.
aparke4 is offline
post #795 of 1039 Old 11-27-2013, 10:43 PM
J03_TJ
But, but, but they say 15.5" for the lowers. Stock is 15.75. Just saying I'd love to find out they go down to 15.5" like in the chart above??
J03_TJ is offline
control arms , duroflex
