How the Metalcloak Duroflex bushing stacks up - Page 3 - JeepForum.com
 1Likes
post #31 of 1039 Old 02-21-2013, 07:35 PM
surfcat2000
MC arms
Put a full set of MC arms in a month ago to replace my stock arms with 65K on them. They are way more solid then the stock but very happy with the lack of noise. Leaving for Moab in a month so it will be fun to compare with the old arms
surfcat2000 is offline
post #32 of 1039 Old 02-21-2013, 07:42 PM
T_K
Originally Posted by Gary2 View Post
I use the OE bushings in front upper axle ends. don't mix JJs and Duroflex on the same arm
I would rather not have the OE bushings. What is the reason for not mixing?
T_K is offline
post #33 of 1039 Old 02-21-2013, 07:50 PM
Gary2
JJs are much harder to rotate so once it is turned the Duroflex would be under constant tension trying to recenter the JJ. With a Duroflex or an OE clevite rubber they both would return to center being its natural for them to do so and remove any uneeded tension on the joints
Gary2 is offline
post #34 of 1039 Old 02-21-2013, 07:52 PM
Jeffro06
Jeffro06's Avatar
This needs to be a tech sticky.
Jeffro06 is offline
post #35 of 1039 Old 02-21-2013, 07:52 PM
jeep1972
Excellent review. Thank you for taking the time to do the write up, it is greatly appreciated.
jeep1972 is offline
post #36 of 1039 Old 02-21-2013, 07:56 PM
jrskihog
Excellent write up!
Sent from my iPad in the middle of the woods
jrskihog is offline
post #37 of 1039 Old 02-21-2013, 08:04 PM
SKINUM
$29 each, to replace the johnny joints in control arms?
SKINUM is offline
post #38 of 1039 Old 02-21-2013, 08:15 PM
scot68
Did you read my signature. I do too
Nope I missed your sig. So obviously I must have also missed Duroflex joints with left hand threads?? I currently run the JJ front housing kit which if I recall also use 2" joints. As you mentioned probably not a good idea to run JJs and Duroflex on the same arm.
scot68 is offline
post #39 of 1039 Old 02-21-2013, 08:22 PM
Gary2
even with one set still running JJs, say on the uppers and Duroflex on the lowers it made a difference. I couldn't afford to do them all at once being I had just bought new Savvy arms . I did them a pair at a time both installing the Savvy's and then later swapping to the Duroflex joints so I got to try many configurations along the way along with occasionally reinstalling a pair of OE arms to get the smoother ride back while swapping things around.
Gary2 is offline
post #40 of 1039 Old 02-21-2013, 08:36 PM
scot68
even with one set still running JJs, say on the uppers and Duroflex on the lowers it made a difference. I couldn't afford to do them all at once being I had just bought new Savvy arms . I did them a pair at a time both installing the Savvy's and then later swapping to the Duroflex joints so I got to try many configurations along the way along with occasionally reinstalling an OE arm to get the smoother ride backwhile swapping things around.
So you did run JJs in your uppers and Duroflex in your lowers at the same time.. Interesting.. You mentioned the ride improved but did you notice any odd handling characteristics?
scot68 is offline
post #41 of 1039 Old 02-21-2013, 09:08 PM
bobthetj03
I run JJ's lowers and stock clevite uppers, so I'd gather results would be similar.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #42 of 1039 Old 02-21-2013, 09:08 PM
Gary2
I started with just front lowers ( Savvy ) then added rear lowers . Swapped a driveshaft so I then added Savvy upper rears and then upper fronts. I had noticed my suspension felt to stiff so I reinstalled the OE rear lower arms and then OEs went back in the upper fronts which improved the ride. Then I became interested in Duroflex . I put the complete duroflex joints in the upper rears ( left and right hand thread ) which softened the ride so then I reinstalled the Savvy rear lowers , the ride was OK . Next came the Complete Duroflex joints for one end of the upper fronts . Then I started with the lowers , just the rebuild type. I did just the front lowers first in case I felt something in the steering I didn't care for I would still have a set of untouched lower Savvy arms in the rear that could go to the front "if " I found the Duroflex had any negative effects on the steering . That was not the case , it was fine up front so I ordered the final set to replace the rear lowers . The only ill effects I had at any time was a stiffer highway ride than I was willing to accept and that was only when I had 14 JJs installed . Now it rides great , nice and smooth.
Gary2 is offline
post #43 of 1039 Old 02-21-2013, 09:21 PM
Gary2
When I had JJs on just the lowers ( F&R ) and OE uppers all was still not bad ride wise. When I started adding the uppers is when my ride went down the tubes.
Gary2 is offline
post #44 of 1039 Old 02-21-2013, 10:01 PM
scot68
I think I'm going to give the Duroflex joints a try in the near future. For the record I am still a huge fan of the Currie JJ however I wouldn't mind if my suspension was a little less stiff. Maybe I'm just getting old..
scot68 is offline
post #45 of 1039 Old 02-21-2013, 11:23 PM
RockRodHooligan
RockRodHooligan's Avatar
He's been raving about them to me, and knowing Connor he takes great pain to make this Jeep handle nice and tight on the road, I wouldn't say he would call the set up with JJs would be what he would describe as "stiff", he has told me that everything is still nice and tight, maybe more so now with the MC joints, but that they do a better job of absorbing shock, all the little bumps and cracks in the road that JJs transfer because of the urethane bushings.
This is a major reason I'm considering these for my Jeepspeed build. Granted that most of the time my rig will be left to DD use and looking pretty, these joints should also help reduce the amount of NVH, keeping as much from being transferred to the chassis, and preserving my precious unibody, both on and offroad.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
control arms , duroflex
