How the Metalcloak Duroflex bushing stacks up - Page 11 - JeepForum.com
 1Likes
post #151 of 1042 Old 02-27-2013, 10:58 AM Thread Starter
Imped
Imped's Avatar
Originally Posted by bobthetj03 View Post
For sure! Right now it's a pipe dream. In reality, I'll be slapping some new clevites in the factory mounts and run it for a while. I'll be picking up some upper arms next week from the MC boys.
That should work just fine for you. You're not gonna be able to run long enough shocks to hit the misalignment limits of the MC bushings at the frame end.
OlllllllO
IndyORV
Imped is offline
post #152 of 1042 Old 02-27-2013, 11:11 AM
bobthetj03
It'll do for now for the kind of wheelin I do. I can't touch some of the stuff you Indy guys tackle!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #153 of 1042 Old 02-27-2013, 11:14 AM
bobthetj03
Originally Posted by J03_TJ View Post
I'd like to hear how inserting the new clevites in the axle mounts goes for you (mostly the casting side). If they are anything like the interference fit of pushing the lower arm clevites into RE control arms, that took all the push my 20 ton press could muster.
I'll be documenting the swap in my build thread. Hoping that some all thread, a couple of well placed sockets, and some patience will get-r-done.
Bob's boring build:
post #154 of 1042 Old 02-27-2013, 12:07 PM
TroubleNEO
You mean the front upper CA bushings on the axle end? Those were fairly easy. I burned them with a torch until the center roll pin slid out, then hit them with a sawzall on the top and bottom. After that I hammered a screw driver in between the bushing and the hole to bend them in. As soon as you get them bent a little they pop right out. Then the new ones were hammered in with a block of wood and big hand sledge.
One of the funniest things I've seen so far working on my Jeep was when one of the roll pins had decided it had enough, made a loud *ZING* sound and forcibly shot out of the bushing right in the middle of heating it. It must have been under a lot of tension that released once the rubber around it got hot.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #155 of 1042 Old 02-27-2013, 12:45 PM Thread Starter
Imped
Imped's Avatar
Yep, every one of those I've ever burned out have shot the sleeve out. I just let them burn until the rubber is all but gone then punch the outer sleeve out.
OlllllllO
IndyORV
Imped is offline
post #156 of 1042 Old 02-27-2013, 08:23 PM
J03_TJ
Thanks for the info. I can just imagine a propane torch (I don't have a cutting torch) and those bushings would be a stinky event. Like all my other work, has to be in the garage so guess I better plan on having the side door open too and hope for a breezy day. Thanks again, sorry again to detour from your MC joint thread.
J03_TJ is online now
post #157 of 1042 Old 02-28-2013, 11:38 AM
aparke4
It's a stinky and nasty affair- I have only had trouble getting the bushing above the pumpkin out when the axle is installed in a jeep... Otherwise there seems to be a voodoo of ease when the axle is out! Burn out the center bushing, ball joint press it out, the sawzall two cuts on the sleeve and it will hammer out. It's the only way I have ever been able to get them out!
Mc duroflex uppers on the axle would be really cool! The currie housing kit is just so easy to install- I am using the currie driver upper and artec truss with currie pass upper. A bare truss and mc housing might install in the artec truss pass side pretty easy. Driver side upper would have to be custom machined with one of mc housing kits.
aparke4 is offline
post #158 of 1042 Old 03-03-2013, 06:51 PM
btn
I can't find much info on Metalcloak's website, but does anyone know the specific type of lubricant needed between the bushing and the barrel? I know you can't use regular chassis grease.
2000 TJ, 4.0L, 4" suspension lift, 35s, rear D44 and front HP30 both with ARBs. AX15, 4:1 T-case.
btn is offline
post #159 of 1042 Old 03-03-2013, 06:55 PM
tjcj
[QUOTE="btn;15072218"]I can't find much info on Metalcloak's website, but does anyone know the specific type of lubricant needed between the bushing and the barrel? I know you can't use regular chassis grease.[/QUOTE/] I believe MC sends the grease with the joint. Or thats what they said in the video Imped linked.
Sent from my XT881 freezeray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #160 of 1042 Old 03-03-2013, 06:56 PM
btn
[quote=tjcj;15072249]
They didn't in my order anyway. Even if they included some, I'd like to have extra on hand.
btn is offline
post #161 of 1042 Old 03-03-2013, 10:57 PM
chmo
If I am not mistaken the same grease which does not attack polyraces (or JJ or Flex Joints) would do.
Daystar has some silicon based teflon grease for their joints ... quite expensive, but only needed once in a while.
DuPont has has some silicon/teflon grease too ...
"The more I know, the more I realize how much I don't know"
chmo is offline
post #162 of 1042 Old 03-04-2013, 05:45 PM
Shadowline
Ordered a set for the front this morning, based on this review. I will say that already I'm impressed with there customer service... Got a call from Will at Metalcloak confirming the order soon after placing it. Very professional and informative, and un-expected. Looking forward to receiving them.
2003 TJ 4.0 5-speed 31inch Goodyear Authority's, 2inch Rubicon Express Springs, Hella Vision Plus H/L's, IPF upgraded H/L wiring harness. JCR Offroad Stage 2 Frt Bumper with CocaCola Bottle opener, Smittybuilt XCR8 Winch, Rampage Bowless top.
Shadowline is offline
post #163 of 1042 Old 03-04-2013, 06:29 PM
aparke4
replacement joints or control arms?
aparke4 is offline
post #164 of 1042 Old 03-04-2013, 07:15 PM
Shadowline
Complete arms...
post #165 of 1042 Old 03-05-2013, 12:14 PM
lactrain
Just ordered my complete set of arms .....
LACTRAINS 05 RUBICON
USA
lactrain is offline
control arms , duroflex
