How the Metalcloak Duroflex bushing stacks up - Page 10 - JeepForum.com
 1Likes
post #136 of 1042 Old 02-26-2013, 01:43 PM
GMBNT42
Yes you have to cut off the jj housing and use mc's housings in its place....
GMBNT42 is offline
post #137 of 1042 Old 02-26-2013, 01:54 PM
SKINUM
I think I'd just leave the front uppers with Johnny joints & replace the rest. I already have replaced the axle mount on my Jeep so it wouldn't be worth the minimal improvement for me.
SKINUM is offline
post #138 of 1042 Old 02-26-2013, 02:03 PM
GMBNT42
Originally Posted by BamaJeepman21 View Post
Could you just order this from Savvy without the JJ and use this Duroflex? Or am I missing something here?
It wouldn't work. You would have to either fab your own or buy a prefabbed set of upper axle control arm mounts....like the Clayton ones.........request them to come without the JJ housings welded on so that you could weld on the MC duroflex housings........thats how you can run duroflex bushings up front at the top axle mounts.
GMBNT42 is offline
post #139 of 1042 Old 02-26-2013, 02:50 PM
scot68
Originally Posted by SKINUM View Post
I think I'd just leave the front uppers with Johnny joints & replace the rest. I already have replaced the axle mounts on my Jeep so it wouldn't be worth the minimal improvement for me.
^^ This is what I'm thinking of doing. I'm just wondering though how it would ride with Duroflex uppers/lowers in the rear but only Duroflex lowers in the front (keeping all 4 JJ uppers)? I wouldn't want the rear end considerably softer than the front end.
scot68 is offline
post #140 of 1042 Old 02-26-2013, 02:58 PM
bobthetj03
Someone needs to make a truss that has tab style bracket mounts for the uppers, then just buy arms with joints at both ends. A truss would simplify having to weld to the cast diff housing, make it stronger, and eliminate the Clevites.
Something like this....
http://claytonoffroad.com/product_in...roducts_id/358
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #141 of 1042 Old 02-26-2013, 06:48 PM
jeepinhokie
That's how I plan to mount my 3 link. Clayton bridge without the link mount. Probably use an artec flat link mount instead.
HOKIES UNITED!
jeepinhokie is offline
post #142 of 1042 Old 02-27-2013, 04:44 AM
mike_dippert
mike_dippert's Avatar
I know it's done quite a bit with D60 builds. Everything I've read says properly welding mild to cast is a PITA. Professionals prefer brazing rather than welding.
mike_dippert is online now
post #143 of 1042 Old 02-27-2013, 07:54 AM Thread Starter
Imped
Imped's Avatar
It welds to the tubes.
I built a simple bridge from 1/2" steel for next to nothing and cut some tabs out of 5/16" plate I had sitting in my steel bin.
You can see it here:
[IMG][/IMG]
OlllllllO
IndyORV
Imped is offline
post #144 of 1042 Old 02-27-2013, 09:21 AM
bobthetj03
I guess it's not rocket science. A bridge like that should be simple enough. How did you weld the bridge to the driver side. There's not much axle tube to weld to between the housing and the spring perch mount.
Bob's boring build:
post #145 of 1042 Old 02-27-2013, 09:26 AM
rchase559
Build new coil buckets that tie into the truss.
rchase559 is offline
post #146 of 1042 Old 02-27-2013, 09:33 AM Thread Starter
Imped
Imped's Avatar
There's not a bracket on that axle that's stock....it was bare tube before I started. The coil buckets and truss tie into each other on the short tube.
OlllllllO
IndyORV
Imped is offline
post #147 of 1042 Old 02-27-2013, 09:44 AM
bobthetj03
Guess I better hit the wrecking yards and find a HP30 to practice on, lol!
Bob's boring build:
post #148 of 1042 Old 02-27-2013, 10:03 AM Thread Starter
Imped
Imped's Avatar
If you plan on doing much welding to a 30, I'd recommend sleeving the tubes to help dissipate that heat out first....and go nice and slow.
OlllllllO
IndyORV
Imped is offline
post #149 of 1042 Old 02-27-2013, 10:24 AM
bobthetj03
For sure! Right now it's a pipe dream. In reality, I'll be slapping some new clevites in the factory mounts and run it for a while. I'll be picking up some upper arms next week from the MC boys.
Bob's boring build:
post #150 of 1042 Old 02-27-2013, 10:35 AM
J03_TJ
I'd like to hear how inserting the new clevites in the axle mounts goes for you (mostly the casting side). If they are anything like the interference fit of pushing the lower arm clevites into RE control arms, that took all the push my 20 ton press could muster.
J03_TJ is offline
control arms , duroflex
