How long should my front brakes last?
| Front and rear Drive shafts @ free shipping | Poison Spyder February Special: FREE Rubber Liners when yo | Slappin' on 61,510 Rigid Industries Lumens for Big Red |
#1 | |
I took my Jeep in for the 30,000 mile service today. The service guy later calls me and tells me that my brake pads are at 1.1 millimeters (I have no idea what percent that is) and that they need to be replaced. Seeing as my brakes were at 40% just 6,000 miles ago, I told him "no way." How does a brake go from almost half there to "practically gone" in only 6,000 miles? I haven't offroaded in that time, so dirt/gravel aren't wearing the brakes. How long are these things supposed to last? Thanks for your help guys. It just felt like he was trying to squeeze extra money out of me.
'Ought Four TJ |
#2 |
not 6,000 miles but if you took it to jeep, they would say your defrapinator needed to be replaced too. my brakes go 20,000 or more miles before replacing. I replace mine maybe once a year. take it somewhere local or look at them yourself, its not hard to do them yourself, 30 minutes
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada |
#3 |
not alot of people realize when they look at the pads that the piston pushes on the inner pad not the outer pad........so in essence your inside pad will wear down faster than your outer pads. most people make the mistake of either just looking through their rim, or just looking at the outer pad and basing their judgement on that. i'd say that about 30,000 on one set isn't that bad. if you still have some concerns they go to the shop and have him show you the pads.
#4 |
It all depends on you driving habits and the road you take. The front brakes on my other car lasted 67,000 miles(8 years) and have plenty of meat left on them. So much I keep them as spares for the track. The rears wore down completely over that time. Check the brakes out yourself. It's time to learn how to now.
I know this guy [name witheld] tried pulling this brake scam on some elder lady at a dealership. He said she needed brakes but he never checked to see if she was in the system. (Big dummy) It just so happens that she was in for a brake job 1 month prior to this visit. Well, he got fired and now works for another dealership making more money. Some people just manage to fail and fall upwards.
4.0L TJ 5.7L CTS 3.7L KJ |
#5 |
Just did my 30000 mile service for $115 in fluids. How much did it cost you? If you don't mind me asking.
Russo |
#6 |
Junior Member
Still on my original front pads with 58K, but I do mostly highway driving.
Blue Jeep Club #145 2005 Wrangler X Patriot Blue 4.0L 6 speed RC 2.5 lift w/ 3/4" front spacers, 2.2 shocks & steering stabilizer. JKS disco's 3.07 gears 31x10.5x15LT Firestone Destination AT |
#7 |
i'm at 31k now, just had all the servicing done and they checked the brakes (cost 45 bucks!) . my fronts are fine, but the rotors are warped (which i already knew), and the rears are at 9/32nd. so everything is wearing fine....but i'm guessing i'll replace them when they start squealing & the front shaking gets worse. i'll prolly get another 10k out of them at least.
30k sucks for a set of brakes. Jeep isn't know for awesome brakes. My dad's WJ needed all new pads and rotors at 24k. When its time to replace mine, I'm going with high quality rotors (like non-slotted PowerSlots), and some high quality pads with a Lifetime warranty. But then again, I plan to keep for jeep for a long time.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#8 | |
Wahoowa
White 01 TJ Sport 4.0 NV3550 |
#9 |
Do it right or not at all
![]() Join Date: Jan 2003
Take your wheel off and look at the pads (you can see them fine once the wheel is off), which is the only way you'll know for sure.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#10 |
your brakes have wear indicators on them. almost all new vehicles do. you'd know if you needed to replace your pads as they would squeal all the time. unless you are shimmying while you are braking, then i wouldnt worry too much about the brakes. next time you go in for service, take it to a local mechanic as i would trust them 1000x more than the dealership's mechanics.
#11 | |
Russo |
#12 |
Thanks you so much guys! Now that I know 30k is reasonable for mostly city driving, I'll go take it to a non-stealership mechanic. One of my neighbors told me about a mechanic that he has been going to for 15 years who is supposed to good and honest. Unfortunately, I can't work on the Jeep at my apartment complex (according to the lease). Once I move into a house I'll learn how to do all this on my own.
'Ought Four TJ |
#13 | |
Russo |
#14 |
I get 33k out of my first set of breaks. I had 35" tires on there for the majority of those miles. Not bad. Besides I spend more in gas and oil than I do swapping the brakes. Its 50 bucks and 30 minutes of my time.
2004 Black Rubicon w/ 5 spd RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch The Reptile File A discussion forum on geckos, lizards, snakes, and other reptiles. |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
