How long does it take to install a lift? - JeepForum.com
post #1 of 19 Old 10-26-2003, 06:43 PM Thread Starter
RubiNoobie
About how long will it take me and a buddy to install a 4.5in RExpress Lift. Ive dropped trucks and bagged them and tore down and built up engines so I mechanically inclined and have a compressor and impact wrench and air tools. So about how many hours to do it me and a buddy?
RubiNoobie is offline
post #2 of 19 Old 10-26-2003, 06:55 PM
WAC_Jeeper
WAC_Jeeper's Avatar
I would say leave a weekend open. It might only take a few hours but it seems like there is always runs to the hardware store or whatnot when I'm wrenching. If this is your first TJ lift I would say around the 7 hour ballpark. But if you leave the whole weekend open and have it done on saturday you can go test it out on sunday. Sounds like you have the tools and skills.
12 JKR 2 door, MCE Gen III Flares, Teraflex 1.5" Perfomance Leveling kit, 35" MTRs, ARB bars front/rear, ARB diff covers, ARB Dual Compressor, AEV DOT-compliant beadlocks, Warn Zeon 8
97 TJ, MCE fenders and flares, heavily used and reliable on 35's.
WAC_Jeeper is offline
post #3 of 19 Old 10-26-2003, 07:03 PM
OverTheHandlebars
OverTheHandlebars's Avatar
it took me and a buddy around 8 hours to put on an ome lift...that includes a trip to the auto parts store for spring compressors.
'02 TJ, 2.5L 5spd
OME HD, JKS BL, Goferit MML,Aussie in the front
33x10.5 BFG muds on the stock steelies
OverTheHandlebars is offline
post #4 of 19 Old 10-26-2003, 07:04 PM
igofshn
Locked @ both ends
igofshn's Avatar
I installed mine in less than 8 hrs without any help. You should easily do it in a day.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #5 of 19 Old 10-29-2003, 12:13 PM
blupupher
blupupher's Avatar
If you have never don a TJ before, with the air tools to help, around 6-8. First one I did took right at 7, but that was with 2 trips to the auto parts store. Probably could do it in 4-5 now.
blupupher is offline
post #6 of 19 Old 10-29-2003, 12:49 PM
TellyDSP
Poland and PPV!!!!
My buddy did his in 3, but 6-8 sounds like a good start on a TJ.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #7 of 19 Old 06-18-2011, 05:27 PM
97CherokeeSport
How long will it take to install an IRO 3.5'' lift with two people?
97CherokeeSport is offline
post #8 of 19 Old 06-18-2011, 05:32 PM
RubiconRazorbac
RubiconRazorbac's Avatar
On what Jeep? If yours is rust-free and the hardware is easy to remove, it's a good long Summer afternoon. If you have rust issues and/or you snap some hardware (especially the rear upper shock mounts), it can take much longer.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #9 of 19 Old 06-18-2011, 05:43 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
How many beer's in your cooler?...
Knuckelhead is offline
post #10 of 19 Old 06-18-2011, 06:05 PM
herbiehind
rust ,rust ,and more rust . add 4 hrs. if you live in rust belt .
herbiehind is offline
post #11 of 19 Old 06-18-2011, 06:57 PM
RubiconRazorbac
Originally Posted by herbiehind
rust ,rust ,and more rust . add 4 DAYS if you live in rust belt .
Fixed it for ya!
2003 TJ Rubicon:
2017 JKU Rubicon:
post #12 of 19 Old 06-18-2011, 07:37 PM
Swacos_tj
took me 7 hours for my rc 4 inch flex including putting flex ends together messing with adjustable control arms and setting toe to drive home and couple 420 breaks
did all but pit man arm, adjusted front sway bars, rear sway bar links and brake lines and another hr or so next after noon in my garage with hand tools finishing everything but brake lines
i did it my work had air tools ect. all bolts spun free and im a mechanic and worked at a hvy/med duty spring shop for 7 years before where im at now, i did it by my self and didnt use any spring compressors and first time doing a tj
and that was after working a 8 hr day came home did a few other things then went back to work about time i headed back home i been up for over 24 hrs then went to bed for 4 hrs and get up and finished it
Swacos_tj is offline
post #13 of 19 Old 06-18-2011, 07:40 PM
Sundowner
Start soaking anything that's rusty in some sort of penetrating oil about two days beforehand and you'll save yourself a headache or two. If you get stuck, crack open a cold one and apply liberal amounts of BFH. Repeat as needed.
Sundowner is offline
post #14 of 19 Old 06-18-2011, 07:42 PM
Swacos_tj
torch is all ways nice
post #15 of 19 Old 06-18-2011, 07:56 PM
red rubi
So long pal!
red rubi's Avatar
about 7 1/2 years would be my guess......
red rubi is offline
BL and budget MML combo install- how long and install details? jondotcom TJ Wrangler Technical Forum 11 10-17-2009 06:52 PM
Bad Long Arm Install Parker1599 TJ Wrangler Technical Forum 25 04-17-2009 07:20 AM
Long arm install greenmachine99 TJ Wrangler Technical Forum 6 04-01-2007 08:53 AM
How long would it take to install.... JackMJeep TJ Wrangler Technical Forum 2 10-11-2006 07:29 PM
How long did it take to install your body lift? tcestes TJ Wrangler Technical Forum 39 09-15-2006 11:02 PM
