How long do you let your Permatex cure before refill? - JeepForum.com
post #1 of 10 Old 09-16-2006, 08:05 PM Thread Starter
FL 4.0L
I just changed the diff fluid in a D44 and I'm anxious to refill it. When I've done it before, I've used the red stuff and let it sit overnight. This time I used the Ultra black, and I need the truck tomorrow morning. So, do I fill it tonight or get up early tomorrow? Package says it takes 24 hrs for a full cure, but that's merely a suggestion, right? Thanks!
FL 4.0L is offline
post #2 of 10 Old 09-16-2006, 08:08 PM
otisdog
2008 WK
Heck I've always filled mine up within an hour.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 10 Old 09-16-2006, 08:22 PM Thread Starter
FL 4.0L
Good. I'll wait for the end of the Tennessee/Florida game and refill. It's late 2nd quarter now.
FL 4.0L is offline
post #4 of 10 Old 09-16-2006, 08:24 PM
daveg13
daveg13's Avatar
5 minutes here, no leaks.
daveg13 is offline
post #5 of 10 Old 09-16-2006, 08:27 PM
koisanke
I figure it usually takes me 10 or 15 minutes to put the second cover back on that would be about how long i wait.
koisanke is offline
post #6 of 10 Old 09-16-2006, 09:28 PM Thread Starter
FL 4.0L
It's done and it's dry. Thanks for the help!
FL 4.0L is offline
post #7 of 10 Old 09-18-2006, 12:19 PM
Claw
I use the gray Mopar Gear Lube RTV. It's specifically designed for use with gear lube, and can be applied even if you don't clean the old fluid off of the mating surfaces. I let it set up for about 20 minutes, although I don't think it's necessary.
'02 Wrangler Sport, 4.0L Auto, D44/D30, ARB lockers, Tera S4T, 33x12.5 BFG MT/KMs, Eagle 589s, Rancho RS 9000s, Warn XD9000i, Wilderness Swing Away, Currie Rockers, Bestop Flares, Cobra 75WXST, Garmin GPS V, etc.
Claw is offline
post #8 of 10 Old 09-18-2006, 12:23 PM
FLATFENDER54
FLATFENDER54's Avatar
By the time you had typed this it was ready.
FLATFENDER54 is offline
post #9 of 10 Old 09-18-2006, 12:32 PM
Rusty the Scoob
Rusty the Scoob's Avatar
Yep. 5 minutes here. I've used blue and black with no problems.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline
post #10 of 10 Old 09-18-2006, 02:14 PM
19OlllllllO41
19OlllllllO41's Avatar
I have always waited about an hour, and have never had a problem with leaks. But in reality, you prob can basically fill it right away/within a few minutes. If you were to take it to a mechanic, they would put the cover back on and fill it right away because they dont have time to waste waiting around for it to dry. So if they can do it that quick and not have leaks, you can too!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
How long to cure? Tray TJ Wrangler Technical Forum 5 05-21-2007 07:52 AM
Ultra Black RTV Permatex good for diff cover? Thunderstrike TJ Wrangler Technical Forum 11 03-07-2006 12:46 PM
Newbie Question: How long do I need to let RTV cure? Russ Chung TJ Wrangler Technical Forum 2 10-08-2005 09:18 AM
touched up underside w Permatex rust neutralizer IAJack TJ Wrangler Technical Forum 0 04-03-2005 12:07 AM
Permatex Red/Blue Shinner YJ Wrangler Technical Forum 11 10-02-2003 01:54 PM
