Quantcast How long do brakes last? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How long do brakes last?
Old 03-27-2007, 10:32 PM   #1
Deezul
jeep has 50k miles......its a Rubi/4wheel discs. Lately the brake pedal has been "fluttering, bouncing" a tiny bit. Enough to notice but also braking distances seem to have trailed longer. How often on average should the pads be swapped out and/or rotors?
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come.
**R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback,
Green jeep club member #139
Deezul is offline   Reply With Quote
Old 03-27-2007, 10:49 PM   #2
Texan4life
I changed mine at 60k.
Texan4life is offline   Reply With Quote
Old 03-27-2007, 11:24 PM   #3
NikVallens
Fluttering/bouncing comes from rotors. Was having the same problem wiht my 2000 sport just under 51k miles. Resurfaced rotors and new pads did the trick. Id give it a shot.
00 TJ with a few mods. Hopefully more someday...
NikVallens is offline   Reply With Quote
Old 03-27-2007, 11:26 PM   #4
RnEmOvr
Never Forget
RnEmOvr's Avatar
you cant really go but mileage as if it all highway will get longer then in city where you use them, and your braking habbits, if they feel funny replace them and dont pull a taco and wait to long
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 03-28-2007, 01:21 AM   #5
GringoLoco
I think Jerry B. made it 198,000 on his factory brakes. lol
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote
Old 03-28-2007, 11:42 AM   #6
PatriotCrawler
mine had the fluttery feeling also----had the rotors turned and it solved the problem.
PatriotCrawler is offline   Reply With Quote
Old 03-28-2007, 11:46 AM   #7
hazmat
I got a pulsation w/5000 miles on the od. city driving.
hazmat is offline   Reply With Quote
Old 03-28-2007, 12:35 PM   #8
04Willys
I had to replace my front pads after about 31K miles.
-=John=-
[COLOR=darkgreen]2004 Willys TJ[/COLOR], 4.0L I6
1994 3000GT VR-4, twin turbo 3.0L V6
"[COLOR=white]The no-mind no-thinks no-thoughts about no-things.[/COLOR]" - The Buddha
04Willys is offline   Reply With Quote
Old 03-28-2007, 12:42 PM   #9
TJinWV
I just replaced my front pads (front discs, rear drums) at about 55k. They were very worn down, and I don't brake much.
Dan - TJinWV <>< | West Virginia Jeep Club
2002 TJ, 2" OME lift, ARBs
TJinWV is offline   Reply With Quote
Old 03-28-2007, 01:42 PM   #10
raskull
I'd say you should take it in while it's still under warranty. Warped rotors seems to be a pretty common problem in the TJs.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 03-28-2007, 01:47 PM   #11
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Asking how long brakes last is kind of like asking how long a bottle of Jack Daniels lasts. In my house, it lasts quite a while but at a close friend's house, not long at all.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-28-2007, 02:05 PM   #12
azcoyote
I have 24K miles on the stockers and so far they look like they have at least 3/4 of the pad remaining.
A better rule of thumb is to pull your wheels off every 10K miles (if not 5K) and have a look...
JEEPLESS... :(
azcoyote is offline   Reply With Quote
Old 03-28-2007, 02:12 PM   #13
bobjp
It depends entirely on your driving style. It is impossible to say how long they "should" last.
Pulsation from the brakes is due to a warped or unevenly warn rotor, but that doesn't mean it needs replacement. As far as I am concerned, if your brakes pulsate you are stepping the pedal too hard. Stepping on the pedal hard will cause the rotors to heat up and warp over time. None of my cars have ever had pulsating brakes, but everyone who I think stops too fast does have pulsating brakes.
You need to pull of your wheel and check the thickness of the pads. The rule of thumb is that the amount padding left should be at least as thick as the metal backing on the pad. I usually go beyond that point, but that is because I know to keep an eye on them. If your rotors are not warped to badly they can be turned. There is no need to waste money on new rotors if the ones you have can be turned.
97 TJ sport. No swaybar. ;)
bobjp is offline   Reply With Quote
Old 03-28-2007, 02:29 PM   #14
rjcarrillo1911
unfortunately, brakes and rotors are not covered by warranty! I just purchased my first Wrangler, an '05 Sport with 14k miles on it, and the rotors feek warped to me. I've had warped rotors before and I'm pretty sure that's what's going on. Also, ABS equipped vehicles will pulsate a little during hard braking.
As far as turning rotors is concerned...they need to be measured and there is a certain measurement printed on the rotor itself, as to what they should not be turned past. If you are close to that measurement then they need to be replaced.
Whenever you turn rotors, you SHOULD put new pads on!
rjcarrillo1911 is offline   Reply With Quote
Old 03-28-2007, 04:10 PM   #15
kizer
Im at 60K on stock front pads. Rears I converted to Disc.
I personally check them once a year and try to remember to check them every oil change. Doesn't hurt to check than to replace later when its to late and your rotors are ruined because your pads ate into them.
Links4Jeeps.com
1600+ Write-ups, and more
My Writeups | My Heap
kizer is offline   Reply With Quote
Glock Forum
