How to KNOW if my driveshaft is too long or too short... write up - JeepForum.com
post #1 of 1 Old 12-31-2011, 10:05 PM Thread Starter
dcope17
Okay... this forum is great with a lot of people having experience to answer questions. I just happened to be getting my front diff back in place ( with about a 1" stretch ) and I needed to see if my DS will work. So here it is... the only way to know beyond the shadow of a doubt that your DS is not too long or too short for your setup.
The first thing I did was to pull off the clamps around the rubber boot and pull the DS splines apart. When I got it apart... I measured the length of the splines and they were 3 1/4" long. So at the fully stuffed position... I had 1/2" of splines showing outside the opposing end meaning that I had 2 3/4" of engagement.
This pic isn't fully stuffed but its close.
Then I drooped the axle fully and measured it again... here I had 1" exposed so I have only 2 1/4" engaged.
So, now I have to decide if it's okay to go with a 2 1/4 engagement... For me personally, I will be having the shaft lengthened cause I can easily have full engagement throughout the entire range of motion.
Anyway... this is the ONLY way to KNOW if your DS will not fall apart or not compress enough and breaking your TC in half. So you can take someones word if it will work but where are they if something goes wrong????
Don't be lazy... check your stuff out!!!!!
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
CV Driveshaft is too short? pwcracer TJ Wrangler Technical Forum 2 06-17-2010 08:30 AM
looking for a good write up on sye/driveshaft eclipse27 TJ Wrangler Technical Forum 3 08-22-2007 02:03 PM
is my driveshaft to short ufatbastehd YJ Wrangler Technical Forum 13 05-11-2007 07:45 AM
Long Arm - Short Story - Short Arm... folkxrock TJ Wrangler Technical Forum 24 08-12-2006 05:23 AM
RE long arm write up eagleno49 TJ Wrangler Technical Forum 6 11-08-2005 06:30 PM
