How to Install a Brake Controller??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to Install a Brake Controller???
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 07-14-2009, 09:34 AM   #1
TJnTennessee
I am wanting to get and install a brake controller for my 2000 TJ Sport. I'm not really sure what I need to get and how to install it. Can anyone point me in the right direction???
TJnTennessee is offline   Reply With Quote
Unread 07-14-2009, 09:38 AM   #2
NotURMailman
NotURMailman's Avatar
Are you reffering to a trailer brake controller?
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
Unread 07-14-2009, 09:40 AM   #3
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Any RV or trailer supply store will carry an assortment of electric brake controllers. I've installed two (TJ and Grand Cherokee) and they were something like $60-70 each IIRC. I installed the TJ under the steering wheel on the plastic housing. It's out of the way yet handy if I need to adjust the braking force while driving.
Basically you connect it to power, ground, and one of the wires on the brake light switch, and then run the brake controller wire to the back of the Jeep where it can be connected to the trailer. The only somewhat PITA part is connecting it to the brake switch wiring.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 07-14-2009, 09:52 AM   #4
TJnTennessee
So the wiring is not just "plug and play"? I'll actually have to do some splicing of wires???
Unread 07-14-2009, 09:56 AM   #5
ncarr
I do believe they have connectors that allow you to plug into the dash, so long as you already have the tow package wiring already setup. Just gotta find the right model for your vehicle.
ncarr is offline   Reply With Quote
Unread 07-14-2009, 10:01 AM   #6
Jerry Bransford
That's not going to be the case with a Wrangler, and it wasn't the case with my wife's Grand Cherokee either even though it came with the factory towing package.
Getting Savvy...
Unread 07-14-2009, 10:16 AM   #7
TJnTennessee
any write-ups out there on the install??
Unread 07-14-2009, 11:55 AM   #8
Junky burp
I connected straight to the battery through a self-resetting 20amp circuit breaker. I also ran a heavy ground from the battery to my trailer plug. I wired a switch between the controller and the brake output wire. The trailer only weighs 350# empty and I turn the brakes off when it's empty. I do ocasionally load up a yard of stone in it though, so the brakes are quite necessary at times. The brake signal wire is simply spliced into the brake pedal wire as Jerry wrote. It really is simple. Just make sure you splice to the "out" side from the switch, or it will affect your gas mileage.
Junky burp is offline   Reply With Quote
Unread 07-14-2009, 04:59 PM   #9
BlueFlame
There will be instructions in the package....
BlueFlame is offline   Reply With Quote
Unread 07-15-2009, 04:46 PM   #10
jpittman
The Prodigy Brake Controller is an excellent unit, has detailed instructions, and is easy to install. The wire you want to tap into on the brake pedal switch is the white/tan wire. To make sure, use a test light.
I got mine from: http://www.etrailer.com/pc-BC~90185.htm
They have the best price that I could fine.
For tech help call 1-800-785-5832. They also have a generic wiring diagram that I used, it's p/n 4399, "Electronic Brake Control Installation."
jpittman is offline   Reply With Quote
Unread 07-15-2009, 05:37 PM   #11
wushaw
Rockin jeep
wushaw's Avatar
The TJ only has a 2k tow limit and in many states trailers do not need brakes till 3k or better so why have the option to have a brake controller.
I don't have one in my TJ due to the handeling characterist of a 2k trailer behind it, I wouldn't want any more.
I did install one in my parents JK and it wasn't too bad just getting under the dash for the wire splices and mounting was a little difficult.
wushaw is offline   Reply With Quote
Unread 07-15-2009, 07:56 PM   #12
jpittman
Wushaw,
You are correct about the maximum tow rate, etc. for the TJ. I put mine on for peace-of-mind. Most of our off- road trips are into the Sierra which are a high altitude climb. I want to have the ability of the trailer to help with braking when coming back down out of the Sierra. My maximum weight is 2k on an off-road tent trailer.
