How I figured out my bumpstops for a 2" BB Install with Skyjacker shocks - JeepForum.com
post #1 of 5 Old 10-13-2010, 04:32 PM Thread Starter
Mike_Motorbike
I started with a 1 3/4" x 1" lift and stockish shocks ( Previous owner had just put in new shocks for stock jeep TJ.
You can read about it here VVVV.
http://www.jeepforum.com/forum/f9/ho...-pics-1025457/
I just added another 1" to the front and back to net a total 2 3/4" in the front and 2" in the back.
The Jeep listed to the passenger side 3/8" "Common Prob"
So I added 3 @ 1/8" spacers to that side front and rear and it worked pretty good.
I ordered some Skyjacker 2" lift shocks
Skyjacker Hydro Shock Absorbers, LOWEST PRICES on Skyjacker Hydro Shocks For $137.95 free shipping...
Quadratec's website lists the shock lengths as.
Front .
Extended: 22.75"aka 3/4"
Collapsed: 13.54" aka just over 1/2"
Eye / Stem
Rear .
Extended: 22.58" aka 9/16" just over
Collapsed: 13.71" aka just under 3/4"
Eye / Eye
I measured them and got...
Front.
Extended: 22.375" aka 3/8"
Collapsed: 13.54" aka 1/2" or very close to it
Rear .
Extended: 22.625" aka 5/8"
Collapsed: 13.75" aka 3/4"
Eye / Eye
The stockish existing one measured
Front.
Extended: 19 7/8"
Collapsed: 12 1/2"
Rear .
Extended: 19 1/2"
Collapsed: 12 1/4"
Eye / Eye
So the front Skyjacker compressed is about 1" longer than stock.
The rear Skyjacker compressed is about 1 1/2" longer than stock.
I removed the spring and used a Jack to fully compress the axle to the bumpstop cup to see if the shocks fit..
I forgot to take an after pic but here you can see I have 1 3/4"s of bumpstop spacers and I have a little over an inch. of space between the shock and the shock mount. So I removed the 1" spacer and left the 3/4" the shock still had about 1/4" clearance.
So only 3/4" was necessary.....
Here I have a 1" bumpstop spacer and the rear Skyjacker still has 1/4" of space...So you only need 1" in the rear.
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #2 of 5 Old 10-13-2010, 04:42 PM Thread Starter
Mike_Motorbike
How to put bushings in
Lub is your friend
Press down with palm while rocking the shock body up and down..
Place pin in vise or the like..
again press with palm and rock..
same with spacer but you can press with the vise..
post #3 of 5 Old 10-13-2010, 05:40 PM Thread Starter
Mike_Motorbike
post #4 of 5 Old 10-13-2010, 09:08 PM Thread Starter
Mike_Motorbike
Oh I got an extra 1-1/4 of UP travel in the front.
But the in the rear only 1/2" to 3/4" since I didn't get a full inch. of lift.
The reason I got the skyjackers is they had the shortest advertised compressed shock length that cost less than $80 a shock......
Also I was making a bracket to reposition the rear lower shock mount to get an extra inch. of travel . But I found out while doing the bump stop tests that the shock will hit the frame if you go towards the tire to much . AND if i didn't have the top 1" bumpstop the spring would barley have a place to hold on to....so I have to have at least 1" bumpstop extension with a 2" BB
post #5 of 5 Old 10-14-2010, 07:15 PM Thread Starter
Mike_Motorbike
This was some of my research for this lift
http://www.jeepforum.com/forum/f9/sh...ngths-1000442/
http://www.jeepforum.com/forum/f9/su...thread-917465/
Skyjacker 2" lift with hydro shocks bozhoz TJ Wrangler Technical Forum 4 02-16-2011 04:50 PM
4" Skyjacker lift. What are the best shocks? natedogg78n TJ Wrangler Technical Forum 0 03-26-2010 05:02 PM
Can I install 2" extended bumpstops without removing the springs? planman TJ Wrangler Technical Forum 8 02-23-2007 03:17 PM
2" Skyjacker Hydro Shocks!!?? Thug Nasty TJ Wrangler Technical Forum 3 07-16-2006 12:51 PM
skyjacker 4" softride w/ Hydro shocks... jackal TJ Wrangler Technical Forum 3 04-23-2004 04:18 PM
