How high and what brand body lift - JeepForum.com
post #1 of 9 Old 10-09-2008, 05:57 PM Thread Starter
lilman
Okay, I'm sorry about posting so much about ordering 35's but tomorrow is the day and I need to know what lift to buy. I am planning on ordering a body lift but am not sure what brand or how high I should go. Can ya'll please recommend how high and what brand? Also, point me to a kit that has everything cause I'm not sure exactly what I will need.
lilman is offline
post #2 of 9 Old 10-09-2008, 06:20 PM
95BadBoy
1.25" JKS, available from most venders that deal in JKS products.
95BadBoy is offline
post #3 of 9 Old 10-09-2008, 06:25 PM Thread Starter
lilman
But since I have a 4'' suspension lift as well, will I need extended brake lines?
lilman is offline
post #4 of 9 Old 10-09-2008, 06:32 PM
Jeffro06
Jeffro06's Avatar
If you have a 4" lift the lines should probably already be extended.
Jeffro06 is offline
post #5 of 9 Old 10-09-2008, 06:34 PM Thread Starter
lilman
I'm pretty sure they aren't. I don't really know, but my brother put the lift on and he never mentioned it. It's a rough country lift kit.
lilman is offline
post #6 of 9 Old 10-09-2008, 06:36 PM
Jeffro06
Jeffro06's Avatar
My 4" RE lift came with the extended lines....go ask your brother.
Jeffro06 is offline
post #7 of 9 Old 10-09-2008, 06:45 PM Thread Starter
lilman
Just got off phone with my brother and he said that he didn't extend brake lines. So should I? I don't wheel at all.
lilman is offline
post #8 of 9 Old 10-09-2008, 06:59 PM
txboy72
you will more than likely need to extend the brake lines. when i put my RE 4.5 on it came with the new brake lines. the original brake lines just werent long enough. so if you have a 4 in on there, surprised they arnt extended already but i would plan on getting the extended lines.
txboy72 is offline
post #9 of 9 Old 10-09-2008, 08:07 PM
RobertTJ
I just installed the JKS 1.25" body lift today, it was easy and simple. The RC lift does not come with extended brake lines. The instructions say you do not need extended brake lines unless you disconnect the anti-sway bar links.
http://www.jeepforum.com/forum/f9/best-body-lift-kit-616608/
RobertTJ is offline
body lift - does it matter the brand? rballman JK Wrangler Technical Forum 6 08-04-2009 02:17 PM
Body mounted sliders used for high lift point bsbretly TJ Wrangler Technical Forum 5 07-12-2009 01:37 PM
High Angle CV shaft still vibrates! Only 6 in's of Lift Including body! Please Help cdooley83 TJ Wrangler Technical Forum 11 02-11-2009 09:10 PM
Body Lift brand differences Faramir66103 TJ Wrangler Technical Forum 3 01-22-2009 06:49 PM
Body Lift company/brand question jim_bert TJ Wrangler Technical Forum 5 08-21-2008 12:14 PM
