how heavy is a hardtop? - JeepForum.com
post #1 of 43 Old 09-15-2006, 01:55 AM Thread Starter
Slaughter
is it a one man job putting it on and off? thanks.
Slaughter is offline
post #2 of 43 Old 09-15-2006, 01:59 AM
TAMUJeep
TAMUJeep's Avatar
heavier than a soft top...I'll tell ya that!
seriously, I have heard that they have gotten heavier, but when I was in college I had a YJ w/hardtop. I would unbolt/move everything stand up in the back and lift the top off with my shoulders/back and walk out of the back of the jeep. Nowadays if I had a hardtop I would rig up somekind of pulley system to help me lift. If I had to guess a weight on the YJ top i'd say 250-300 pounds...but it was a few years back and I have had a beer or two since.
TAMUJeep is offline
post #3 of 43 Old 09-15-2006, 02:37 AM
daveg13
daveg13's Avatar
Two person job, unless you have some kind of lift/hoist setup. It's not that heavy, just bulky. Probably around 100 lbs.
daveg13 is offline
post #4 of 43 Old 09-15-2006, 02:39 AM
TAMUJeep
TAMUJeep's Avatar
^^^^^^^Wuss...j/k...you think it's just a hundred pounds? Thats not much.
TAMUJeep is offline
post #5 of 43 Old 09-15-2006, 04:06 AM
thesherm
thesherm's Avatar
one person can lift but it is extremely cumbersome to maneuver. the back window is prone to pop open. it is a 30 second job with two people.
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #6 of 43 Old 09-15-2006, 05:28 AM
Chris_
i tried it by myself and almost ended up having to purchase a new one.
i screwed eyelets into the 2X4s in the ceiling so i had one on each corner. i got 4 ratchets straps and hooked them to the 4 eyelets. now i just back under it, undo the screws and latches, hook on, ratchet up, and drive out. i have one on each side at the front, and two that i hook to each side at the top of the back window. total cost? $15.87.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #7 of 43 Old 09-15-2006, 07:01 AM
Jeepin' Rock Cl
IIRC the top from my '02 is 140lbs.
Jeepin' Rock Cl is offline
post #8 of 43 Old 09-15-2006, 07:26 AM
TXST8tj
TXST8tj's Avatar
140-150 lbs
as mentioned, it's bulky. two person job to do it safely, health wise and breakage wise.
Patrick
TXST8tj is offline
post #9 of 43 Old 09-15-2006, 07:39 AM
msavard
msavard's Avatar
Agreed on it being a 2 person job without a hoist.
There is no way I'd EVER try to get mine off solo. Sure... you can lift it... no problem. And there's about a 50% chance you'll get it off safely without breaking anything.
...Then there's that other 50% chance that you break the window or crack the top and you're out hundreds of dollars.
I'm assuming all of you have at least ONE friend or aquaintance you know well enough to come over and help you throw your hard top on at the end of the summer
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto 35" Maxxis Bighorns D30/D44 w 4.88 Gears 2.5" OME LJ/XJ lift JKS Trackbars Brown Dog MML 1" BL Warn Engine Skid Aussie Locker (FR) / Rubi Air Locker (REAR) SYE/CV Nth Adj Control Arms Bestop Oversize Tire Carrier PSC Rocker Knockers ORO Swayloc TNT Tube Fenders
msavard is offline
post #10 of 43 Old 09-15-2006, 08:22 AM
wrangler2002
according to Chrysler its 140lbs. You need to people or a one person hitch.
wrangler2002 is offline
post #11 of 43 Old 09-15-2006, 08:57 AM
The Mean Fish
The Mean Fish's Avatar
I took mine off alone one time, it's not to heavy to lift but it's so hard to balance that it's not worth the risk of dropping it. It's a quick 2 person job.
The Mean Fish is offline
post #12 of 43 Old 09-15-2006, 09:00 AM
SecondTJ
SecondTJ's Avatar
i think its easily a 2 person job, i wouldnt even attempt to do it by myself
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #13 of 43 Old 09-15-2006, 09:02 AM
Gritz
Gritz's Avatar
Took it off by myself the first time, not fun! Built a hoist and have never looked back.
Gritz
Patriot Blue 2000 Sport
2" REBB, JKS Quicker Disco's
4.0 w/5-Spd
dual tops
"It is believed dinosaurs are extinct due to a giant meteor. That's true if you want to call Chuck Norris a giant meteor."
Gritz is offline
post #14 of 43 Old 09-15-2006, 09:19 AM
EaglesSJ
EaglesSJ's Avatar
Just like the others said its not that heavy but if you screw up lifting it by yourself and drop it, itll cost you about 900-1000 bucks for your mistake, its much easier to just go get a friend to help, or in this case my 5' wife and put it on. I have heard that the lifts work real nice but I live in base housing and cant just start screwing things into my carport.
EaglesSJ is offline
post #15 of 43 Old 09-15-2006, 09:35 AM
Jay Lu
2006 TJ X bone stock
2014 WK
I have had this hard top issue with my 2000 TJ. There are times when helper is not available, and the garage is not my own. I ended up buying a soft top. But I have thought about this a lot and here is my idea:
Jay Lu is offline
Remove Hardtop Glass to Repaint Hardtop?? nibblesupreme TJ Wrangler Technical Forum 12 02-02-2010 09:56 AM
Storing hardtop on Lange hardtop hoist? TJDaveX Wrangler General Discussion 4 06-29-2009 11:20 AM
OME HK (Heavy Duty) Suspension Kit- Launch Time Without Heavy Bumper? hikerpaddler TJ Wrangler Technical Forum 8 03-11-2009 11:50 AM
Cure for hardtop squeek and offroading with hardtop? 06WranglerX TJ Wrangler Technical Forum 15 07-02-2006 05:09 PM
Factory Hardtop vs. Bestop Hardtop (review) MadDawg TJ Wrangler Technical Forum 2 12-17-2005 08:35 AM
