How hard is removing fuel tank and lines? - JeepForum.com
post #1 of 9 Old 06-13-2013, 03:51 PM Thread Starter
T-Mav
I will be starting in my frame repair tommorow. What all is involved on removing the tank and what else do I need to know? Also I cut off my buddies uca mounts off a 06 mine is a 99 I'm assuming there the same? I will just be patching in pieces,
T-Mav is offline
post #2 of 9 Old 06-13-2013, 03:54 PM
Benderff
Benderff's Avatar
I believe Rokmen has a video for installing a gas tank skid that shows dropping the tank. It's very easy, as long as your tank is not full.
The UCA are the same.
Good luck.
Edit:
Benderff is offline
post #3 of 9 Old 06-14-2013, 09:17 AM
armyRN
armyRN's Avatar
Location: Longview, WA (one hour north of Portland, OR)
A transmission jack makes dropping the gas tank (and putting it back in place) much easier. They're not expensive if you get one at Harbor Freight.
armyRN is offline
post #4 of 9 Old 06-14-2013, 09:54 AM
Jeepin72
IMO this was the hardest part! Make sure it is as empty as you can get it. I used an old table leave and a floor jack.
Also, I had a bear of a time reaching in and trying to undo the red retaining clip so I could undo the wiring for the fuel pump assy. My wiring had enough slack that I was able to shimmy the extra toward the tank so I could drop it to the floor and then screw with the connector.
Jeepin72 is offline
post #5 of 9 Old 06-14-2013, 10:00 AM
NotURMailman
NotURMailman's Avatar
If you go to HF looking for a jack to make fuel tank removal/install easier I would suggest thier ATV jack. It has a large rubber pad on top and is a bit cheaper than transmission jack.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 9 Old 06-14-2013, 11:07 AM Thread Starter
T-Mav
I have a motorcycle jack. Thanks for info guys
T-Mav is offline
post #7 of 9 Old 06-14-2013, 11:58 AM
J03_TJ
Not sure about the '99, but on mine it's kind of important that you depressurization the fuel lines prior to disconnecting them. That and a jack, first couple times I did it with a floor jack and a piece of wood, kind if a pain I the butt alone, now I have a tranny jack, hoping to find out that makes it easier being able to strap it to the jack.
J03_TJ is offline
post #8 of 9 Old 06-14-2013, 11:59 AM
NotURMailman
Don't forget to disconnect the filler neck!
post #9 of 9 Old 06-14-2013, 12:39 PM
mg2380
That's what I used.
mg2380 is offline
