How hard is it to remove hard door glass? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How hard is it to remove hard door glass?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 06-03-2006, 10:59 AM   #1
T.H's TJ
When i replace my window tint i would like to take the glass out. But I have never had inner door skin off. How hard of job its it?
T.H's TJ is offline   Reply With Quote
Unread 06-03-2006, 11:14 AM   #2
RnEmOvr
Will tow
RnEmOvr's Avatar
you dont need to take apart door, but it is very easy, screws along bottom, 2 on the stap handle, and corner piece and grab and pull, then to put it on make sure pins are on skin side and line em up and hit em in
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
FBI data shows that 323 murders were committed with rifles of any kind in 2011. In comparison, 496 murders were committed with hammers and clubs, and 1,694 murders were perpetrated with knives.
RnEmOvr is offline   Reply With Quote
Unread 06-03-2006, 12:33 PM   #3
T.H's TJ
I'll have to go look but u lost me at screws along the bottom.
Edit: are you telling how to take the door apart? or take the window out? why don't i need to take it apart?
Unread 06-03-2006, 01:07 PM   #4
BlueFlame
DZ's description made no sense to me at all.
Taking off the door panel is easy enough; remove the screws along the edges, remove the pull handle, remove the window crank (pop out the clip on the back side.) Then pull it out to unsnap the clips, then lift it upwards and slide it away from the body. Easier to do than write. Peel off the plastic protector from the door.
As for the window -
Put the window all the way down.
Remove the guide channel from the the triangular plastic piece in the corner of the window opening.
Remove the screws from it and remove the triangular plastic piece.
Roll the window up about 1/4 of the way to get to the screws in the regulator arm.
Remove the screws that attach the regulator arm to the glass channel.
Lift the glass upward while tilting inward and remove it from the door.
BlueFlame is offline   Reply With Quote
