How hard is it to install rear drum brake pads? - JeepForum.com
post #1 of 7 Old 08-04-2004, 10:34 AM Thread Starter
97grntjsahara
i am doing the fronts right now and i looked at the rears and they are pretty worn. Anyone have a writeup or some info on how to change them. Thanks!
97 Wrangler Sahara*-The mean green machine-*
Green Jeep Club Member #90
Sahara Jeep Club Member #1
-RE 3.5"springs/DT3000
-RE Front Adj. Trackbar
-JKS Quick Disco's
-Banks Header
-32" BFG AT's on Cragar Soft 8's
-Warn Receiver Shackle
Future Mods:Body Armor
97grntjsahara is offline
post #2 of 7 Old 08-04-2004, 02:01 PM
Jay-Mac
Jay-Mac's Avatar
dont have a write up but do one side at a time so u can look back at the other when u forget how to put the orginal side together.....
2000 Sport Amber Fire, 5 Spd, A/C, dual tops....
Where has all the money gone.......
REBB and rubi springs
chopped tube bumpers
warn m8000
optima yellow top
31X10.5 BFG'S MT'S
Near Future Mods:
Garvin wilderness rack and basket
Arb Snorkel
Safari/duster/windjammer combo sealed?
Famous Last Words "Hold onto your panties!.....SH*T"
Jay-Mac is offline
post #3 of 7 Old 08-04-2004, 02:51 PM
ColoradoSkier
ColoradoSkier's Avatar
Get an FSM
Chester Bullock,
98 TJ,
1" ProComp springs, 31" BFG AT's,
Tenxible Solutions
Website Hosting, Design and Marketing
ColoradoSkier is offline
post #4 of 7 Old 08-04-2004, 03:45 PM
NakedJeeper
NakedJeeper's Avatar
There are some special brake tools that make the job a lot easier. Stretching and compressing the springs can be a pain with a screw driver and pliers. Beyond that its not rocket science. Those guys at the local garage did not take 8 years of auto shop to learn to change brakes.
Also, you should bleed them when you change them. Got a friend or SpeedBleeder?
NakedJeeper is offline
post #5 of 7 Old 08-04-2004, 09:19 PM
BNovak
BNovak's Avatar
97' - I had the same thoughts last week before I started my rear brakes.
Turns out, they were a heckuva lot easier than I ever thought they would be. I did it using the Haynes manual, so that helps...
Either way if you have the book you shouldn't have any problems. When you buy the new drum pads, get the $7 brake wrench - well worth it even if you only use it once. Along with that, have some good sized needle nose pliers (2 pair) handy and a screwdriver. Other than that, I don't think I really used much else in the way of tools.
One trick tat everyone has said to use though - either take both wheels and drums off and use one for a reference, or take a picture and print it out BEFORE you start so you know how all the springs go back in.
For a first timer, the first side will cause a lot of cussing, second side is a bit easier. It took me about 2.5hours total for both sides, but I ended up jacking it up again the next day to get the proportioning correct.
Hope this helps.
-_BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #6 of 7 Old 08-04-2004, 09:20 PM
BNovak
BNovak's Avatar
Oh yeah, one other trick I learned.
Get a medium sized box and fill it with shredded papers...(I used old CC reciepts - they work great!) and when you take the outer drum off, spray the interior bits and pieces with brake cleaner. I used about a can per side.
Put the box under the brakes so it drips into the shredded paper. No mess on the garage floor!
--BN
BNovak is offline
post #7 of 7 Old 08-05-2004, 10:42 AM
Chipper
Chipper's Avatar
I've always done my own brakes and I always swore like a trooper when it came time to either take the springs off or to put them back on ....UNTIL.....I bought a brake spring tool. It looks kinda like a screwdriver with the handle in the middle of the shaft. One end is made to take off and put on the hold-down springs, the other end is for the return springs. It costs about $5 and is worth it's weight in gold.
I'll never do drum brakes without one.
http://www.bobstools.net/Store/LS46750.html
Chip
2000 TJ...Almost stock
Quick Discos and MT/R's.
Chipper is offline
Rear Drum Brake Help - Tight Drum AFTER new shoes! rastadog TJ Wrangler Technical Forum 31 10-21-2011 05:19 PM
New Brake Pads and Rotor-Install Questions tdog522 TJ Wrangler Technical Forum 7 01-21-2009 10:22 PM
drum won't fit over new brake pads UTmike TJ Wrangler Technical Forum 40 01-13-2007 02:29 PM
Best rear drum pads? Paul DK TJ Wrangler Technical Forum 18 10-19-2006 05:36 AM
How Do I install new brake pads? Drew99 TJ Wrangler Technical Forum 9 04-05-2003 03:43 PM
