Quantcast How hard is it to install a body lift?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How hard is it to install a body lift??
Old 08-08-2005, 01:43 PM   #1
NEWtoTHEjeepLIF
Can I do it by myself? What kind of tools do I need for the install....... Is there heavy lifting??? Does anyone have step by step instructions? With pictures? Yes I am a newbie and need your help! Thanks!
NEWtoTHEjeepLIF is offline   Reply With Quote
Old 08-08-2005, 01:49 PM   #2
RubiconSS
If you are new to it, mind sharing as to why the BL? How high is it and what all are you looking to accomplish?
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline   Reply With Quote
Old 08-08-2005, 01:49 PM   #3
habers
http://4x4xplor.com/bl.html
2002 [color=yellow][b]TJ[/b][/color] Sport | 4.0L | Manual | D44 3.73
REBB | JKS 1.25" BL | M.O.R.E. 1" MML
32X11.5 BFG AT | MT Classic II
habers is offline   Reply With Quote
Old 08-08-2005, 02:08 PM   #4
martinsburgjeep
I is the laws
martinsburgjeep's Avatar
I just did it with the help of my dad, but am sure that I could have done it myself. The real issue wasn't the body lift, I would have no issues doing that myself. I am very glad that the old man was around to help with the motor mount lift.
If I can do it . . . anybody can do it. There wasn't any heavy lifting, well other than what was done by the jack.
I read through the 4X4explor link posted above before I did mine and would recommend it.
loosing™ Kieth™ anywone™ nothing to loose™ sheap™ terrists™ lack of carrying™ 50+ tards away™ noxt™ frie™ deliciouse™ are'nt™ i's™ bin too™ reccomend™ base™ reasony™ gon't™ carbon figer™ copywrite™ discusted™ sence™ the 2ed time™ snaped™ frosen™ tryed™ evaryhting™ mecdonalds™ obbiously™ herd an seen™ everythan™ you feeelings™ beleive™ deamed™ responcible™ disscuss™ pasific™ imagain™ canadian providance™ secrete society™ Did'nt™ facimily™ clainming™ hearitage™ unseccessfull™ fromm™ forgotton™ a mute point™ unfortunatly™ odopted™ awsome™ uningured™ sarcasim™ hilariouse™ they'res™ noes™ rutine™ seliniod™ jared™ colud™ hosehold™ perchest™ alots™ stuped™ purfact™ marridge™ soon of God™ heresay™ chunck™ I have bean™ tred™ it works grate™ hear are some™ dusent™ trimed™ panted up™ weakend™ you's™ stold™ weekest™ plade™
martinsburgjeep is offline   Reply With Quote
Old 08-08-2005, 02:30 PM   #5
PDX_XJ
I'm 5'5" - 140lbs, and had just finished chemotherapy the week I did mine. Unless you have some serious debilitating condition, you're certainly able to do this yourself. I managed MORE motor mounts too in the same weekend, but it took much longer than I expected, and I learned a vital lesson about parking in the low spot of your driveway and unbolting the engine: It will rain on you.
A jack (the bottle jack that comes with your jeep can work in a pinch), a socket set and extentions, plus some blocks of wood. Some liquid wrench might also be a neccesity.
The bottle jack worked better for the tight spot you need to put it than the floor jack. Just stack a 4x4 underneath it and 2x4's above it. Floor jack is neccesary for a MML.
A torque wrench isn't neccesary - you basically tighen until the rubber mounts start to squish.
Nope.
Someone else posted an excellent link.
Well, we're glad to offer it. Welcome aboard.
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline   Reply With Quote
Old 08-08-2005, 05:09 PM   #6
habers
Can you elaborate on the "rain on you part", I am planning on installing the MML and BL this weekend
Thanks
Old 08-08-2005, 05:34 PM   #7
Runnin87
i am also curious.. about how long did it take you guys to do it yourself?
00' TJ
Black
33" mud terrians, 3" BDS lift, 4.56, wilderness front and rear bumpers, A to Z rockers, KC lights, tints
Runnin87 is offline   Reply With Quote
Old 08-08-2005, 05:50 PM   #8
TJVigilante
Thanks
It means it'll rain. On you. the sky will dump its watery load all over your head.
Engine + low spot = you have no way of moving the jeep to another spot.
TJVigilante is offline   Reply With Quote
Old 08-08-2005, 05:56 PM   #9
Rocky529
Jeep
Rocky529's Avatar
Took me 2 hours only because I took my time. It's real easy... loosen all the bolts on one side (5) and leave them threaded. Completely remove the other 6 (1 under the radiator) and then jack up the body. Slide in your 1" pucks and thread your bolts. Lower the body... do the same to the other side and you are done. Drop your radiator an inch or install a MML and you are completely done. Don't worry about your t-case linkage... it should shift fine.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 08-08-2005, 06:25 PM   #10
jeephreak
I did a BL and a MML 2 weeks ago, no joke the BL took 25 minutes. (it was my second time doing it and I had air tools). The MML with the rubicon was a little more difficult than I thought, the mounts went in fine, but getting bolts to fit b/c of placement of other parts was a pain, over all 3 hours for both. DANG that MML!
the write up on 4x4explore is what i used.
2005 Rubicon
lifted, some big tires, some of this, some of that...
MY RIG
r.i.p. Cap'n Crunch
jeephreak is offline   Reply With Quote
Old 08-08-2005, 07:41 PM   #11
martinsburgjeep
I is the laws
the body lift really only took about an hour for me, but most of that time was cramming, or trying to cram, the two bumper like thingies (I believe that is the technical term) up front. The MML took a little longer because I could not get the bolts from the kit started. All in all, including installation of discos took about 4 and a half hours
Old 08-14-2005, 10:22 AM   #12
davenjeip
We did one yesterday in under an hour, plus another half hour modifying the fan shroud.
The only reason it even took that long was due to the new rubber bumpers under the grill.
I just lined mine up with the holes and let the weight of the Jeep pop them in. I think it took a couple hundred miles of bouncing before they seated right.
The way we did it yesterday was more correct. It took us most of the time messing with them trying to get them to pop into the holes.
2003 TJ
1967 M715
[URL=http://www.davenjeip.com][b][color=red]www.davenjeip.com[/color][/b][/URL]
davenjeip is offline   Reply With Quote
Old 08-14-2005, 11:05 AM   #13
Hunter9
Took me about 2 hours working by myself, with most of that time working on the MML . I used air tools so that helped a lot. The BL from Performace Accesories has the bolt in front bumpers under the headlights. It made the task MUCH easier. I did not even have to remove the headlights to do it, just the trim pieces. Just used a telescoping magnet to place the bolts in the holes and a 1/4" ratchet and extension to hold it.
If you have some help it should go even faster.
[CENTER][COLOR=White]97 Sport [/COLOR] 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
[COLOR="Red"]Former 3.07 Gears Club Member #1[/CENTER][/COLOR]
Hunter9 is offline   Reply With Quote
Old 08-14-2005, 11:32 AM   #14
blackZZR
took me about 2 minutes to review the bill and write the check
didn't even need to wash my hands afterwards and no cuts or bruises
blackZZR is offline   Reply With Quote
Old 08-14-2005, 02:52 PM   #15
TexanTJ
Took me two nights after work, taking my time, and with dinner breaks. But i did a 2" and had to extend the gas fill hose. The hardest part had to to be messing with the tc shift bracket and then adjusting the t case.
2005 Bright Silver Metallic X D30/8.8 lsd, 2.5" Skycrapper springs, TNT Phantoms front/ Genright hi-clear Rear. D30 Lockright, LOD Rear Swingout, hardtop, hard and soft upper doors, Bestop bikini/jammer/duster, Bestop SuperTop, HacknTap, 8000lb Gorilla, Magnaflow, Moabs. 285/75R16s Firestone Destination ATs, Smittybilt XRC Stinger
2006 GTO M6- Under 20k miles... Garage Queen
TexanTJ is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
